adjusting cat backs
Old Jul 6, 2014 | 04:32 PM
frankb's Avatar
frankb
Default adjusting cat backs
Are the nuts that hold the H pipe to the cat backs do the adjusting. I could bring the back where I had them installed but if it's just the one nut on each pipe I think I can do them. Is there a distance from the bumper for height( up and down). Also one seems to stick out father then the other. So can these 2 problems be fixed with the one nut that holds the cat backs to the H pipe?
Old Jul 6, 2014 | 04:49 PM
saplumr's Avatar
saplumr
You need to loosen and re-adjust all 4 clamps (2 muff and 2 axle pipe). Twist, turn, push and pull until all tips are level then tighten all. Using a flat bar or board under the tips really helps.
Old Jul 6, 2014 | 05:17 PM
SUB VETTE's Avatar
SUB VETTE
SUBVETTE
Since you paid someone to install them, let them loosen clamps and tweek them until they are level and satisfactory to your eye.
Old Jul 6, 2014 | 05:19 PM
VET4LES's Avatar
VET4LES
Mine only had two clamps at the end of the mid pipe. I installed Corsa Sports and they were the same.
Old Jul 6, 2014 | 05:54 PM
frankb's Avatar
frankb
yes, mine are the same but are B&B prt. I was thinking of saving time by doing them myself. Thanks
Old Jul 6, 2014 | 06:13 PM
VET4LES's Avatar
VET4LES
I don't blame you. You will do it the way you want also.
To adjusting cat backs
