Overheating in traffic
Old Jul 6, 2014 | 08:55 PM
carpayne's Avatar
carpayne
Default Overheating in traffic
2011 grand sport overheating in traffic, cooling fan not running.
Have ck fan with power & it run fine, no overheated wires or connectors.
Is it possible for ecu to be the problem? I have replace fan control module, does any one know if module has to be reprogrammed? Tks for any help
P.s. Car has 19,000 miles
Old Jul 6, 2014 | 09:07 PM
EVRose's Avatar
EVRose
What temps are you seeing?
Old Jul 6, 2014 | 09:08 PM
Sunset-C6's Avatar
Sunset-C6
Stay out of traffic
Old Jul 6, 2014 | 09:50 PM
VET4LES's Avatar
VET4LES
Old Jul 6, 2014 | 11:33 PM
LUVMINE's Avatar
LUVMINE
St. Jude Donor '13-'14-'15-'16-'17-'18-'19-'20-'21-'22
Happened on my Ford Taurus SHO. It was the fan relay switch. Eventually lead to a recall. Not sure if that's your problem.
Old Jul 7, 2014 | 08:04 AM
EBvette02's Avatar
EBvette02
On my 2002, I sucked up a plastic bag and it wound itself around a fan motor. There are 2, and they kick it at different times. I would check to make sure that both fans are turning on. It sounds like you only have 1.
Old Jul 7, 2014 | 08:13 AM
Mad*Max's Avatar
Mad*Max
Originally Posted by VET4LES
Old Jul 7, 2014 | 09:41 AM
EVRose's Avatar
EVRose
C6 only has one fan.
Old Jul 7, 2014 | 02:16 PM
carpayne's Avatar
carpayne
temp will go to 240 & ac cuts off at 230, i ck radiator for trash it was fine
Old Jul 7, 2014 | 02:30 PM
psxer989's Avatar
psxer989
What kind of outside temps are you driving in? Here in L.A. it has been hot and humid. When I get stuck in traffic (very slow stop and go) where my outside temp gauge reads in the high 90's or 100's, my car always runs hot with the AC on. There's no air moving over the ac condenser to cool it off and that heats up the air being pulled to my radiator. Once traffic clears up and I drive for a bit the temp comes down. I added a 8" fan to my condenser and put in a manual switch so I can cool the condenser when sitting still in a traffic jam and it took care of the problem.
Old Jul 7, 2014 | 02:39 PM
grandsport6's Avatar
grandsport6
If you have access to a scan tool like a Tech 2 you can go to the special functions section and manually activate the fan. Check for power at the connector at the fan when the engine is running and ac is on. If there is no power then back track from there. Yes, the PCM turns the fan on and off as commanded.
To Overheating in traffic
