Dealer Rant
In over 40,000 miles I have never used an additive; top tier gas only. And I have never had a problem.
Just sayin...
Just sayin...
How is the business supposed to "work on your car for free"?
The mechanic that plugs in the scanner is probably flat rate.. the dealer has to pay him.. do you work for nothing? I swear sometimes the arrogance "we" exude is almost embarrassing...
you're driving newer corvette, act like it.
Instead the dealer charges you 99 bucks and you go somewhere else and have it done. Guess they want to make there living 99 bucks at a time..
Autozone, Advance Auto, NAPA,and others read the same code for FREE. They get your business because, they have the right idea that customers will buy parts from them when they provide a service at no charge.. Makes good business sense to me! But hey what do I know I only drive a newer corvette so I must not be acting like it..
As for these parts stores.... the employee is either hourly or salary, they aren't losing anything, and the store, what if the part doesn't fix the problem, are they going to reimburse you for the labor....... no, so what are they losing ?????
I used to give away code reading, but its not diagnostics its a code. I used to give away cheap oil changes and other services, but I don't anymore, and guess what, revenue and car count went up. I quit wasting my time with people that only wanted cheap or free services.
I thought I needed it to compete, but I didn't, quality service and good customer relations is what keeps them coming back.
If fuel sloshes over to the passenger tank, the passenger tank will push it back over to the drivers tank (sensor sees fuel, and turn the transfer pump back on).
Number 3 is the line out to the injectors from the fuel pump in the drivers tank, 5 is the transfer line, 8 the transfer pump, 9 the sensor to shut the pump off when the tank goes dry, and note the fuel levels in the tanks showing the fuel being used in the passenger tank first.
As for the use of techron, if the sensor prongs on the arms get so badly worn out from rubbing against corrosion on the contact pad before you start using techron, it may be too late for Techron to work (pad gets clean, but the wear to the swipe arm legs already done).
Don't know for sure in the below video if such as the case (appears to be), since it looks like the use of Techron before he pulled the tank cleaned the contact pads on the sensor, but the problem at hand at this point was the the wiper arm prongs worn out from rubbing up against the corrode pad before the techron was used to clean the pad after the wipers where already worn out.
So the point, use techron to keep the pad clean, which will give the longest life out of the arm swiper's as well.
1:26 on the video shows the arm swiper ends worn out from rubbing up against a corrode pad.
Did I read it is a 9 year old car? If you want warranty try buying a new car. Problem solved. Whine ended.
Reading a code isn't worth $100.
Who do you thinks pays for the techs tools, the shop?
Does the doctor provide free services because you come in there all the time.... I've never seen it.
Because you feel you deserve stuff for free because you frequent someplace is just stinki' thinkin' in my book.
