05 Ac and overheating issue
Old Jul 14, 2014 | 10:30 PM
Youngdarrion's Avatar
Youngdarrion
Default 05 Ac and overheating issue
The other night I was driving had the Ac on and it began blowing warm so I turned it off looked down at my temp gauge and it was at 230-240 which isn't normal it never goes over 220 so I got on the highway and the more I accelerated the more the temp went up it went too about 250 then I shut the car off til it cooled down then I drove it home I changed the thermostat and now it's overheating in 10 min or less any ideas on what it can be?
Old Jul 14, 2014 | 10:40 PM
dlind4's Avatar
dlind4
Check to see if somethings blocking the radiator like a plastic bag or something. If not see if you have a leak somewhere and your low on coolant .
Old Jul 14, 2014 | 10:48 PM
COMMANDER2OOO's Avatar
COMMANDER2OOO
2017 Corvette of Year Finalist
2016 C5 of Year Finalist
are u reading the oil temp or coolant temp ? because that sounds normal for the oil temp
Old Jul 14, 2014 | 10:52 PM
Rebel 1's Avatar
Rebel 1
Did you get all of the air out of the cooling system after install of new stat?
Old Jul 14, 2014 | 10:55 PM
Jimbeaux's Avatar
Jimbeaux
After the stat change, you may have air in the system, or it was a poor quality stat. Check closely for leaks in the radiator as well gently flush with low pressure water the cooling fins on the radiator. They can become quite dirty with build up.
I just had the radiator on my 05 replaced due to a leak I found. The temps were running between 200 and 230 routinely. Now they are 10 to 25 degrees cooler.
Old Jul 15, 2014 | 12:29 AM
Youngdarrion
How do I get the air out of the coolant system?
Old Jul 15, 2014 | 06:07 AM
tennblkc6's Avatar
tennblkc6
have you verified the fans are working?
Old Jul 15, 2014 | 12:23 PM
Youngdarrion
Fans are working and I bled the coolant system today and it's running at about 235 on the highway and 228-230 on the street but if I drive it hard the temp rises I slowed down once it got too 240 any ideas? Seems too run cooler on the street than highway
Old Jul 15, 2014 | 12:58 PM
EVRose's Avatar
EVRose
Wow, this is a tough one. I might try running with no T-stat in it so you can rule that out or not. If it overheats with no tstat then I'd think there was a blockage somewhere in the system.
Old Jul 15, 2014 | 01:24 PM
Youngdarrion
I found the issue there was a trash bag on my radiator blocking it thanks for the help guys and keep a eye on the radiators for debris blocking it
To 05 Ac and overheating issue
