2005 A/C Controller Going Crazy?
Old Jul 23, 2014 | 09:42 PM
Corvette ED's Avatar
Corvette ED
From: Pottsville, PA. USA Home Of America's Oldest Brewery Yuengling
Default 2005 A/C Controller Going Crazy?
Anybody have this problem. 2005 Corvette the A/C controller will work ok and then the display will start blinking. The number will blink, you can't change the temp or the fan speed. Shut the car off and restart it and it is normal again. Also sometime when you start it nothing displays and turning the ***** doesn't work. Once it was set on both sides at 65 and the display worked and the air cond stopped. I shut the car off and restarted it and it worked fine.
Do you think the A/C controller head is bad?
Old Jul 24, 2014 | 06:51 AM
bill K's Avatar
bill K
Default A/c
Had the same problem you need to replace A/C Heat display unit in dash. look on Ebay buy a new one takes about 1/2 hour to install
Old Jul 24, 2014 | 09:07 AM
08velocity's Avatar
08velocity
St. Jude Donor '13
ours does the same thing, we have found that pushing both buttons at the same time turns it on and works like it should , regarding the post about replacing the unit , does it have to be reprogrammed ?
Old Jul 24, 2014 | 09:54 AM
dcarter0001's Avatar
dcarter0001
no reprogramming. cost about $275 on line and fairly easy to replace. good instructions on here on how to do it. common problem.
Old Jul 24, 2014 | 10:38 AM
Patman's Avatar
Patman
I had that problem occur on my 05 last fall a few times before I put it away for the winter, but since bringing it out it hasn't done it again and I've driven it quite a lot too. So I'm hoping I can get a few years out of it before the head unit needs to be done. I had to replace one AC head unit in my C5 (before I knew about the easy fix posted here) due to the display going dim, and it wasn't cheap.
Old Jul 24, 2014 | 01:26 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
That is great info, billk/dcarter! Never even knew there was a head unit for the a/c. I'm adding this info to my files. Thanks!!!
Old Jul 24, 2014 | 03:30 PM
Corvette ED
Thanks I just checked with Contemporary Corvette and they get $200 and have it in stock.
To 2005 A/C Controller Going Crazy?
