'08 headlight issue
Old Jul 30, 2014 | 11:05 AM
badass02ws6's Avatar
badass02ws6
Default '08 headlight issue
hi all been on here for awhile but don't post . just enjoy looking at all the great cars and reading about everything. now i have a problem i hope you people can give me an answer to. my low beam headlights shut off after about 30 minutes of driving . if i let the car sit for a few hours they will work . it is like the auto sensor is heating up . any help would be greatly appreciated . the car is an '08 base model .
Old Jul 30, 2014 | 11:56 AM
Dano523's Avatar
Dano523
There is a recall now for 2005 to 2007 vets, and the problem is there is a wire routed in the fuse block that was bent too tight at one bend, and when the wire gets hot, it will crack at the tight bend to cause current lose.
Go to post #85
https://www.corvetteforum.com/c6-cor...dlights-5.html a
Old Jul 30, 2014 | 12:47 PM
badass02ws6
Go to post #85
Thank you very much . That is a good post. Going to try fixing it this weekend . Again thank you . You helped get rid of my headache over this issue . I knew i would find the answer here . Every body on here is awesome .
Old Jul 30, 2014 | 12:49 PM
cclive's Avatar
cclive
Your symptoms are exactly the problem shown in that thread. If you are handy, fix it yourself rather than let them replace the entire fuse box.
Old Jul 30, 2014 | 04:18 PM
Chevy Cust Svc's Avatar
Chevy Cust Svc
Hey badass02ws6,
Please send us a PM with your VIN and mileage, along with what you experienced. I would like to take a look into this for you.
Marissa
Chevrolet Customer Care
Old Jul 30, 2014 | 05:03 PM
John B.'s Avatar
John B.
I recieved a letter from GM that they would fix the problem for free under the recall,but they don't have the parts yet.They would send another letter when the parts are in makes you want to scream,but we keep picking up the soap
Old Jul 30, 2014 | 06:00 PM
Vette_DD's Avatar
Vette_DD
And has been posted here several times lately, including here:
http://forums.corvetteforum.com/c6-c...6s-merged.html
Usually a good idea to check the stickies first.
Old Jul 30, 2014 | 07:28 PM
SUB VETTE's Avatar
SUB VETTE
SUBVETTE
The recall doesn't replace the whole box as once was thought it might do.
Old Jul 30, 2014 | 07:53 PM
cclive's Avatar
cclive
Interesting...do you know how they are fixing it? Are they having the mechanic replace that one wire?
Old Jul 31, 2014 | 03:51 PM
SUB VETTE's Avatar
SUB VETTE
SUBVETTE
The recall letter says "the dealer will install a jumper wire to correct this condition for you at no cost"
Old Jul 31, 2014 | 05:30 PM
cclive's Avatar
cclive
OK, thanks for the info. I'd rather have a jumper than replace a known good fuse box (other than the one wire, of course...)
Old Aug 1, 2014 | 08:10 AM
FortMorganAl's Avatar
FortMorganAl
From: Currently somewhere in IL,IN,KY,TN,MO,AR,MS,AL, or FL
Originally Posted by Tbong
...Another thing if it is just a jumper What parts is GM waiting for?
I haven't gotten the letter yet but from reading this I would guess that GM is having a jumper manufactured rather than trust a "Corvette Tech" to make a jumper and do any better than the company that built the fuse box to begin with. Remember most of these "Expert Corvette Technicians" are also "Expert Silvarado Technicians" and "Expert Cobalt Technicians" and could have been "Expert McDonald's Burger Chefs" last month. The repair needs to be as foolproof and plug and play as possible. A jumper makes more sense than replacing the entire box with another box that is very likely to be the same design as the one that has failed on a few hundred cars over the years. But fixing 100,000 cars takes a lot of jumpers and I can understand GM not being able to design, produce, and distribute them in just a few months.
BTW, statistically this is a very infrequent issue so rather than trust a dealer to put a jumper or new box on my car for a problem that has almost no chance of ever occuring and has an easy workaround of just turning on the high beams or fog lights until you get it fixed, I will be putting the letter in the glove box.
Old Aug 1, 2014 | 02:03 PM
cclive's Avatar
cclive
I couldn't agree more. GM can't ask a tech to go down to Radio Shack and buy some wire in whatever gauge and then use a pair of pliers to bend it perfectly and replace the wire in the box that may or may not ever go bad. They have to figure out exactly what needs to be changed in that bad wire and then get a supplier (probably the fuse box maker) to make up a replacement wire, package it and get it out to the dealership...in addition to writing a good set of instructions for all those Silverado Expert Techs. This all has to be done under the watchful eye of corporate lawyers who are especially sensitive to GM's possible liability in matters like this...there are plaintiffs lawyers out there that are going to try to get money for just about anyone involved in an accident in a GM car over the past decade and blame it on an ignition switch flaw. Low beam headlights going out could be a big liability concern for GM, so this has to be handled right.
I also agree that I would keep the letter but would not be taking my car in to let a Silverado Expert replace that wire. I know what needs to be done and how unlikely it is that it will ever need to be done on my car. It is also not something that I consider to be a threat to me when I can just hit the high beams if my low beams go out.
To '08 headlight issue
