Clutch/Ranger Method
Old Jul 30, 2014 | 02:15 PM
HarleyEarl1953's Avatar
HarleyEarl1953
Default Clutch/Ranger Method
This forum has been an invaluable source of info. I was researching a lot of various topics and watched the Ranger video on changing/maintaining clutch fluid.
When I got into the car this am, I noticed it was tough to shift to reverse. I noticed some general stickiness with the stick driving around today. I thought about the Ranger method, and decided to take a look at my fluid. Pitch black, which surprises me with only owning it two+ weeks. Plus, it's a 2013 stock coupe with 6,000 miles on it, so I'm still surprised it's as dirty as it is. Nonetheless, the GM Certification process for CPO cars apparently didn't involve changing my clutch fluid. So, a few questions for this non-DIY'er that's going to try this method.
1) does any DOT4 work? Are there any that are supposedly better than others?
2) in videos and pics, I've seen some that say clutch/brake fluid, and some that just say brake fluid. Does this matter? Trying to be very careful with 3 yrs bumper-to-bumper warranty left.
3) I've seen that the fluid is corrosive and to be careful with it. Just how corrosive is it? By that, I mean what type of container should I use to place the spent fluid in?
Method seems very straightforward, and I'm a general DIY'er around the house and with computers. Just never done much on the car. Any help is greatly appreciated!!
Old Jul 30, 2014 | 02:28 PM
Pittcorvette's Avatar
Pittcorvette
https://www.corvetteforum.com/c6-corvette-general-discussion/3454932-ranger-method-clutch-fluid-question.html
Old Jul 30, 2014 | 02:30 PM
Kvothe's Avatar
Kvothe
I use the Prestone Dot 4. It's cheap and available. If you track your car you may want to find something with a higher boil point.
Clutch fluid is brake fluid. There is no specific clutch fluid.
I use an old water bottle or small Gatorade bottle to put the spent fluid in.
I don't know how corrosive the fluid is but if you get it on your paint make sure to wipe it up quick. I lay down paper shop towels when I'm changing the fluid. I also have a fender cover I lay down so if I drip anything it goes on that or the towel. Just be careful and make sure you put the cap back on before pumping the clutch peddle. Some here have forgotten and ended up with a big mess!
Old Jul 30, 2014 | 02:31 PM
Pittcorvette
Check out this video.
Take Care of Your Clutch--the Ranger Protocol: http://youtu.be/gBbsy0LjUvE
Old Jul 30, 2014 | 02:42 PM
Pittcorvette
Exactly the same thing, prestone dot 4 synthetic, in my corvette and did the same things to change the fluid. Take your time with it. It made a HUGE DIFFERENCE. The shifts are like butter.
Things that are needed.
Prestone Dot4 synthetic brake fluid
Scott shop towels
One mix mizer
One empty water bottle.
All can be purchased at a Wal mart for less than 20 bucks.
To Clutch/Ranger Method
