Starting Problems
Old Jul 31, 2014 | 12:12 PM
Gary-kq6rt's Avatar
Gary-kq6rt
Default Starting Problems
2008 C6 base coupe with approximately 52k miles
When I hit the starter button all the lights go out and nothing happens, it's as if the battery were no longer connected. After a few seconds the lights come back on and I can try again. Sometimes it starts on the second try, but other times two or three attempts.
My first thought is that it was time for a new battery, but that didn't help. Once I am driving down the road the voltage shows 14.1 - 14.3 volts, so I know it's charging.
Any thoughts?
Old Jul 31, 2014 | 01:50 PM
cclive's Avatar
cclive
These are classic symptoms of a bad battery. The 14.1-14.3 that you are seeing on the DIC is the voltage being produced by the alternator...it means that there is enough voltage to charge the battery, not that the battery is actually taking that charge. I would load test the battery..anyplace that sells batteries can do this. The voltage alone is not important...it is the voltage that the battery can maintain against a large load that is important.
Old Jul 31, 2014 | 02:57 PM
Gary-kq6rt's Avatar
Gary-kq6rt
The first thing I did was to replace the battery and it didn't make any difference. I also checked the charging voltage as a way of verifying the charging system was working. My brand new battery has 12.6 volts before I hit the key, so I think I can eliminate the battery as the source of the problem
Old Jul 31, 2014 | 03:56 PM
SUB VETTE's Avatar
SUB VETTE
SUBVETTE
Check the cable connections to make sure they are tight and not corroded, particularly at the starter. The starter connection has been known to loosen or corrode.
Old Jul 31, 2014 | 05:31 PM
cclive's Avatar
cclive
Then I agree with this. I did not realize that the battery had been replaced.
Old Aug 2, 2014 | 11:52 AM
Gary-kq6rt's Avatar
Gary-kq6rt
Well I found the problem, a broken starter solenoid. The post for the battery cable was completly broken off.
I haven't had any luck finding just a solenoid and our local Chevy dealer wants $495 for a rebuilt starter. He said he couldn't even find a part number for a new starter.
As expensive as it is I do at least feel better knowing what it is.
Old Aug 2, 2014 | 12:58 PM
cclive's Avatar
cclive
That's a ridiculous price...new aftermarket starters that are better than oem have been purchased for far less here on the forum...do the search.
Old Aug 2, 2014 | 01:38 PM
SUB VETTE's Avatar
SUB VETTE
SUBVETTE
Rock Auto is another place to check for a good price.
Old Aug 2, 2014 | 11:14 PM
charlie-vette's Avatar
charlie-vette
"New OEM Factory GM Starter Chevrolet Corvette C6" on eBay: $125.00
Old Aug 2, 2014 | 11:36 PM
cclive's Avatar
cclive
MSD and B&M are both on Amazon for right around $200...high quality aftermarket...better than OEM.
Old Aug 4, 2014 | 10:31 AM
Gary-kq6rt's Avatar
Gary-kq6rt
I ended up buying a rebuilt starter from my local Napa store for $99.
Thank you to everyone who replied
Old Aug 4, 2014 | 11:17 AM
cclive's Avatar
cclive
Excellent...good job.
Old Aug 4, 2014 | 12:10 PM
SUB VETTE's Avatar
SUB VETTE
SUBVETTE
Glad to see you succeeded in fixing the problem
To Starting Problems
