500hp
Old Aug 2, 2014 | 12:52 AM
killakane1427's Avatar
killakane1427
Default 500hp
What times do you think a 2011 c6 would turn in the quarter mile.500hp 6spd
Old Aug 2, 2014 | 12:58 AM
Garret's Avatar
Garret
I believe in the Beer Fairy
Depends on the driver
Old Aug 2, 2014 | 01:20 AM
ProfessorDeath's Avatar
ProfessorDeath
St. Jude Donor '13-'14
impossible to determine. Perfect conditions, perfect launch, perfect shifts and perfect wheel spin? Low 11's.
realistically? Low 12's.
Old Aug 2, 2014 | 03:22 PM
killakane1427
With mt streets with light weld rims
Old Aug 2, 2014 | 04:50 PM
slolane's Avatar
slolane
CI 7-8-9 Veteran
St. Jude Donor '07-'08 & '12
Should be about the same as Z06 times maybe a bit better because of the narrow body and lighter wheels and tires
Old Aug 2, 2014 | 05:44 PM
JAvery20's Avatar
JAvery20
Low 11's @125. I'm assuming the car launches w/ the tire setup.
Old Aug 2, 2014 | 06:12 PM
dennis50nj's Avatar
dennis50nj
If Gary 2004 Z06 drives it 10.5-10.3if your talking rwhp
killakane1427
Thanks guys
Old Aug 2, 2014 | 09:44 PM
Nosferatu's Avatar
Nosferatu
St. Jude Donor '14
nah...Z06 are underrated and make 460-470rwhp which puts you beyond 505hp. I make close to 500 crank horsepower (428rwhp) and ran 11.7 @ 122 on street tires. Manual non-z51/gs.
Old Aug 2, 2014 | 10:44 PM
NYC6's Avatar
NYC6
Stick, auto, gears, rwhp, weight, bhp, track, conditions, driver......
Way too many variables. Just do it!
Old Aug 2, 2014 | 11:43 PM
JAvery20's Avatar
JAvery20
Get some sticky tires man! You'll really bring down that et.
Old Aug 3, 2014 | 12:28 AM
615C6's Avatar
615C6
Made a pass the other night. 05 ls2 all stock with 100 shot on street tires. First time running the car. Launched and 2k rpm and still had traction issues. I spun 1st and through 2nd. I had a terrible time of 12.954 and a trap speed of 117mph. Can't wait to run the car again and learn to launch the car better. Tire psi was at 25lbs also.
Old Aug 3, 2014 | 06:49 AM
Nosferatu's Avatar
Nosferatu
St. Jude Donor '14
street tires 1.8 60'. I think I'm at the limit of street tires
Old Aug 3, 2014 | 10:36 AM
killakane1427
Yea those mt streets should hook real good. Hoping for low 11 and a miracle to get in the 10s
Old Aug 3, 2014 | 11:46 AM
HOXXOH's Avatar
HOXXOH
I'm less HP, yet ran 11.4 on Invos 3 years ago while just having fun in the middle of a 6K road trip. High 10's/low 11's are normal with DR's.
I think you need a different dyno and tuner.
Old Aug 3, 2014 | 01:31 PM
killakane1427
Default what
Why do i need a new dyno or tuner
Old Aug 3, 2014 | 02:47 PM
JAvery20's Avatar
JAvery20
I went 11.9@123 in my c5 with a vararam and a 100 shot on street tires. Dump those tires, whatever they are. Spray it after your out about 30 ft or so.
To 500hp
Old Aug 3, 2014 | 03:53 PM
dennis50nj's Avatar
dennis50nj
I think Tom was talking about nosferatu
Old Aug 3, 2014 | 10:42 PM
TLS_Addict's Avatar
TLS_Addict
I have been in Nosferatu's car. It is tuned well and runs great.
Old Aug 4, 2014 | 12:39 AM
HOXXOH's Avatar
HOXXOH
It may feel great as a passenger, but if he really has that much HP (500crank/428wheel), he should be running quicker than 11.7 @122. Either the dyno number is inflated or the tune is holding him back. With only headers and a tune, I'd highly suspect the dyno # is off. Admittedly, it's not easy to launch on street tires, so 11.7 with around 400-410 whp sounds closer to reality.
The '06 Z06 was the first car to have the HP rating done under the new standardized method that required certified conditions. http://www.sae.org/certifiedpower/details.htm
The 505 HP is real and most Z's are in the 440 whp range. The Z06 fast list for bone stock w/OEM tires has plenty of cars 11.7 and quicker.
