V-Led Switchback install
Old Aug 2, 2014 | 12:40 PM
LD85's Avatar
LD85
Default V-Led Switchback install
OK, installed the V-Led 6k Switchbacks this morning, took 45 minutes for the pass side, mostly figuring stuff out, i.e. mounting etc, and 15-20 for the driver side, pass side is tight, driver side is wide open,,,I did not connect the dimmer
I removed the tire on each side for easy access, short story = no hyperflash AND I have Eagle Eye turn signals in the rear.
Since the V-Led box gets hot, I put this DEI insulation onto the sidewall and mounted the V-Led box onto it.
DEI
Mounted
Video
Old Aug 2, 2014 | 04:59 PM
tennblkc6's Avatar
tennblkc6
nice..I experienced hyperflash until I installed 2 resistors.
Old Aug 2, 2014 | 08:23 PM
LD85's Avatar
LD85
Well, I have the resistors in case I need them.
Old Aug 25, 2014 | 10:32 AM
LD85's Avatar
LD85
OK very weird, Hyper Flash seems to come and go, so I will install the Resistors this week.
Old Sep 1, 2014 | 06:00 PM
LD85's Avatar
LD85
I installed the capacitors I bought from V-Led, and there is no hyperflash, we drove Friday from INDY to Bowling Green KY and Saturday back and there were no issues, so I'm pleased
To V-Led Switchback install
