Just a quick question.
Old Aug 2, 2014 | 01:49 PM
Sevitz5's Avatar
Sevitz5
Default Just a quick question.
I just cleaned the contacts on my door handles and my electrical system went haywire. I hooked up a tender before I started and had the doors open for maybe a half an hour along with the hood (05 with light). As I was finishing, the hatch popped open for no reason. I then climbed inside and DIC said no fob detected. Aftrr a couple tries it recognized the fob, I started the car and let it idle for couple minutes. The hatch then closed and all appears ok now.
Is this normal if a battery is getting low? Maybe need a new battery? Thanks.
Old Aug 2, 2014 | 01:54 PM
VET4LES's Avatar
VET4LES
A low battery can cause many electrical issues. The best bet is to have a load test done on it. Most auto parts stores will do it with no charge.
Old Aug 2, 2014 | 02:09 PM
Sevitz5's Avatar
Sevitz5
You would think that the interior light would time out and shut off. Guess the engineers forgot that feature on our cars.
Old Aug 2, 2014 | 02:15 PM
SUB VETTE's Avatar
SUB VETTE
SUBVETTE
Had the same thing happen several years ago when I had the doors open for an extended period of time while doing interior mods. Recharged the battery with my tender and the problem vanished.
Old Aug 2, 2014 | 02:22 PM
Sevitz5's Avatar
Sevitz5
Ok...sounds like a normal thing. Thanks for the replies guys.
Old Aug 2, 2014 | 03:02 PM
cclive's Avatar
cclive
The tender is a great idea but it does not put out enough current to compensate for the draw from all the things that happen when a door is left open for a long time. A low battery can certainly cause many weird issues.
EVRose's Avatar
EVRose
All lights do time out after about 15-20 minutes.
To Just a quick question.
