I have a 2008 C6 Z51 coupe with GS widebody mod and z06 brakes front and rear. I used custom three-piece wheels, but kept the stock z06 widths and offsets. I am now considering increasing the outside lip by 1/2" on the fronts and rears. I would do this by replacing the outside lip with one that is 1/2" wider, trimming 1/4" off the center piece where it mates to the hub, and leaving the inside lip as is. This will push the inside lip toward the center of the car 1/4" (approx. 6.5mm) and push the outside lip away from the center of the car 1/4" (approx. 6.5mm). It looks like the wheel and tire will still sit inside the edge of the fenders. Not sure about inside clearance.
I will use Nitto 285 front and 335 rear, which I am running now on the z06 spec'd custom rims.
Does anyone have insight to this mod I am considering?
Thanks for the link, but it does not answer my question. I am looking for someone that has experience fitting non-stock wheels on a C6. I am most concerned with the clearance on the inside and when the front wheels are turned.
how about put a 1/4 inch wheel spacer on and try it, most auto stores or pep boys have them
That would tell me what is happening on the outside of the wheel but not on the inside. I am shaving off 1/4" from the center, which will push the wheel in 1/4". This will result in the 1/2" wider outer lip only pushing the wheel a net 1/4" outward. I need to know if the 1/4" movement inward will cause any interference.
how about add a 1/4 of self adhesive door foam around the tire edge or strips
Remove the rear spring and the shock, then you can move the wheel you have through the full range of motion. Then measure what room you have to see if the extra 1/4" will be an issue.
What width wheel and offset do you have now? All you're doing is putting a half inch wider wheel on the car with the same offset that you have now. Also, what tire size will you run?
Are you sure the lug nuts will have enough thickness in the hub after you take 1/4 inch off of it?
--Dan
The wheels are stock z06 width and offset. Since I am adding 1/2" on the outer lip and trimming 1/4" from the center, the effect is that the wheel will sit 1/4" more in and the outer lip will stick out 1/4" more than the current setup. I will run stock tire size on front and 345/30r19 on rear. 1/4" will leave the minimum thickness for safe operation.
My concern is interference of the inside lip, because it will move 1/4" closer to things adjacent to the wheels.
Rather than me having to look up sizes and such it will be helpful for you to post them since you are looking for information. It keep us on the same page in case one of us is mistaken in what we think is being used.
You'll have no issues with clearance when adding a 1/2" wider wheel with the same offset. Your current backspacing in front is 6.82". The new wheel will be 7.07".
On my front street wheels I run a 7.94" backspacing and 8.03" with race wheels. Both will touch slightly at full lock but that's with 295 and 305 tires respectively. You'll have lots of room.
On the rear, you now have 8.82" backspacing. New will be 9.32". I run a 9.36" backspacing on my race wheels with a 335 tire and no issues.
As was suggested, stick a lump of putty or gum on your wheel and tire and the extreme edges and give it a turn or a slow drive.
Personally, I don't think you'd have any problem just adding the 1/2" to the outside without cutting the hub down. That would certainly relieve any concern you have for clearance to the inside and save money. Again, stick some putty on it and take a drive. At worst, you can add some camber to tuck the top of the tire in. I can't tell you from actual experience on the outside measurements as I have a base model, but ... your fenders are out an extra 1.5", so ...
