Wheel Spacers
Old Aug 5, 2014 | 07:01 AM
ALLEN007's Avatar
ALLEN007
Default Wheel Spacers
I replaced the Bridgestone tires that came with my car with new Michelins (the same size). Bridgestone were not run flats, Michelins are run flats. But the Michelins seem to be a bit narrower than the Bridgestones. Pep Boys have 1/4" wheel spacers, I'm assuming this is what I would use to kick them out a bit. Also, would I have to have longer studs? Might be a dumb question but I appreciate your answer.
Old Aug 5, 2014 | 07:50 AM
jasonc6vette's Avatar
jasonc6vette
4th Gear
Im currently running 1/4" spacers on the rear without longer studs. I did a lot of reading on this forum. What I found was that 1/4" is the max you would want to go while using the stock length studs.
Old Aug 5, 2014 | 07:51 AM
ALLEN007's Avatar
ALLEN007
Thanks! That's what I was wanting to know.
Old Aug 5, 2014 | 11:53 AM
marc8090's Avatar
marc8090
While a 1/4" spacer works with stock studs, that is only advisable with E/T (extended thread) lug nuts, NOT stock ones.
Old Aug 5, 2014 | 11:57 AM
MBB's Avatar
MBB
I ran 1/4" spacers all around for over a year on my old car. I used open end lugs and had no issues. I would NOT advise using stock lugs unless you replaced the stock studs with longer ones.
To Wheel Spacers
