Just to clarify, I don't think my C6Z is too loud most of the time...just thought I'd see what I could do with some simple changes. Thought I'd document it for those who search for similar solutions, so they have better information than I did. I've previously owned cars with low-profile tires. I know the noise will get worse as they wear. Maybe the modifications will have more impact then.
As for tire pressure...the tires are rated to 50 p.s.i. cold. The car rides too much like a Cadillac at 34 p.s.i., so I thought I'd try something different.
My 06 vert isn't too noisy especially with FS WO RFs but the heat is much too prevalent from the under dash to the trunk. GM should have known that the discerning Uber Sport Touring Car buyer would have paid for proper insulation.
amen brother!!
Yes, the fuzzy wheelwell liners do make a significant reduction in wheel noise. But, they are a bear to get clean. **** car cleaners be warned. When I get around to starting installing insulation the first step will be insulating the wheel wells inside and out, and applying a layer inside the wheel liner. Worn highway surfaces plus Badyear RFs seem to produce the most of the noise. On fresh new asphalt the car is super quiet.
Next will be the bulkhead behind the seats. A double layer of foam-aluminum insulation worked wonders in the C5.
Exhaust and engine noise yea, tire noise nay!
50 is the maximum safe pressure not the correct pressure. 34 psi will wear out the center of the tread fast.
The results of the cargo partition surprise me, or maybe not. Perhaps it's just that I'm getting more usable music from my rear speakers that it seems to cut interior noise down. It seems that a lot of the sound from the rear speakers gets lost in the hatch area, so once the divider is installed, much more of that sound is reflected toward the front.
My Corvette is the first true sports car that I have ever owned, and I don't think the interior noise is objectionable. I honestly don't think it is any noisier inside than either the Firebird or Datsun 260Z that I have owned previously. Certainly I would expect a vette to have a little more noise than a lot of passenger cars. When I am out on the road, it isn't something that I give a lot of thought to.
Maybe I'm in the minority lately about this but I like my light weight, raucous sports car. That's part if the appeal of it for me.
Nope...I'm right there with ya. This sounds like another typical case of someone buying a sports car and hoping it has all the characteristic's of a Caddilac. And a Z-06 to boot. If I had a Z-06 I'd be wanting to hear that motor sing and them tires squeal....LOL.
We used to spray rubberized undercoating in the wheel wells.Wonder if that would help on the 013?……You know,I got some old **** carpet somewhere.mmmph
I'd like to know why GM failed to not only add sound deafening mats but also failed to insulate the cabin and trunk from the heat in the driveline tunnel. Is it the expense or the weight? Can it cost (that) much or weigh (that) much?
It was weight. Dave Hill addressed the issue once and said they were looking to shave ounces here and there so adding "X" pounds of sound deadener was never on the table.
I went to Lowes and bought 5 rolls of peel n seal and went to work putting in in the cargo area behind the seats under the floor,as far as I could pull the carpet up without removing the console ,and in the doors,that coupled with removing the runcraps did a world of difference.
I pulled the interior and insulated the whole interior. Helps not only with noise but also with heat. On long trips my headers would heat up the tunnel area so much my left leg would get pretty hot. This and getting rid of the GY runcraps helps.....nothing else does.
It takes some effort to reduce interior noise but not to hard to do.
I had the same results as the OP when checking sound insulation mods to my 2007 Z51 MZ6 Corvette coupe. After insulating many areas in the car and not seeing any difference on my cell phone noise meter, I was surprised as the car seemed much quieter and the music much better.
So, after some online research, it became apparent the problem was with the cell phone noise meter as it only used the dBA weighting which truncates sound below 1000hz. Once I bought a real noise meter that has both dBA and dBC ranges, I could assess the results below 1000hz to just below 100hz using dBC. But, this was after I had completed most of the sound insulation and can not show the step by step improvements.
My final results are 68 dBA and 88 dBC for my C6 at 70 mph with Michelin A/S, complete ZR1 exhaust system in quiet mode with mild to wild switch. Insulating the doors provided a nice noise level reduction and improvement in the 3LT Bose system sound.
I agree ... my C6 is not objectionably noisy. But my C5 was. I bought it when it was a year old and the previous owner had installed a Borla catback (two 4-inch tips) and it was really loud, as well as having the drone. I insulated it and it quietened it down quite a bit. But the C6 is fine as is as far as I'm concerned.
What the tires are rated at has no bearing, that figure is strictly a MAX inflation value. Inside the drivers door are the recommended cold inflation requirements for the vehicle. The only thing 50 psi cold will do is wear the tires out from the crown. Also the handling will be very unusual, to say the least.
Have wondered about spraying the wheelwells with bed liner. Anyone tried that?
No. But years ago we would spray down the fender/1/4 panel wells with rubberized undercoating.Basically the same product.Wonder if they still make it??Anyone?
I have the GY run flats. What run flats are everyone switching to, i.e. that are quieter? I believe most of the annoying noise is the tires as the noise changes based on road conditions.
Rckt,
From my post above and a portion repeated below, I switched to Michelin A/S which are all season run flats which are rather quiet. I am interested in the noise level of C7 Michelin Pilot Super Sport ZP tires that are used as original equipment when compared to the Michelin A/S ZP that I have.
"My final results are 68 dBA and 88 dBC for my C6 at 70 mph with Michelin A/S, complete ZR1 exhaust system in quiet mode with mild to wild switch. Insulating the doors provided a nice noise level reduction and improvement in the 3LT Bose system sound."
