C6 Header Install Question
Old Aug 13, 2014 | 09:50 PM
ellitto's Avatar
ellitto
Default C6 Header Install Question
Hello everyone,
I had a few questions regarding installing headers on a base C6. I have tried to find a very detailed write-up but I haven't found anything for someone who has never changed the headers before. I recently removed the spark plugs but when I took them out the metal housing and spring came out with it. Is this normal? How do I go about putting it back. Also, I am not familiar with O2 sensors whatsoever. How do I remove these to get the headers out. Any help would be greatly appreciated!
Thank you,
Gabe
Old Aug 13, 2014 | 10:16 PM
Guinzu's Avatar
Guinzu
This is a pretty good write up.
http://forums.corvetteforum.com/c6-t...ll-thread.html
Should only need basic tools, o2 sensor socket.
Old Aug 14, 2014 | 10:48 AM
ellitto's Avatar
ellitto
Thank you Guinzu.
Could someone tell me if the metal housings around the spark plugs were supposed to come out? How do I put them back in? Also, how do i remove/install the O2 sensors?
Old Aug 14, 2014 | 07:39 PM
Guinzu's Avatar
Guinzu
The metal shield around the spark plugs do come out. They should just push back in. Careful, they can cut your fingers good.
The o2 sensors are removed using an o2 sensor socket. Like this
Old Aug 15, 2014 | 12:16 PM
ellitto's Avatar
ellitto
Thank you so much! I'm gonna continue to work on this when I get home. Hopefully I won't have any more questions haha.
Old Aug 16, 2014 | 04:53 PM
ellitto's Avatar
ellitto
What are the torque specs on the o2 sensors?'
Also, the header torque specs is 18lbs correct?
Old Aug 16, 2014 | 05:21 PM
0v3rc10ck3d's Avatar
0v3rc10ck3d
I think i read somewhere you torque it to 11lbs then retorque them all to 15lbs?
Old Aug 16, 2014 | 06:11 PM
racerxrick's Avatar
racerxrick
btw...a lot of people (including reputable shops) toss the pretty stainless fasteners away and use the factory exhaust manifold bolts. Also, use a new set of GM gaskets...chuck the Fel pro's that came with the headers in the trash.
To C6 Header Install Question
