Houston Paint Correction
Old Aug 14, 2014 | 01:06 PM
LbulletM's Avatar
LbulletM
Default Houston Paint Correction
Does anybody know of a good, decently priced detailer that does paint correction in the Houston area? I would do it myself, but I'm really worried about messing something up.
Old Aug 14, 2014 | 01:11 PM
Too-Fast's Avatar
Too-Fast
Active Streak: 90 Days
2024 C6 of the Year Winner - Modified
You may want to post this in the Southwest section.
Old Aug 14, 2014 | 01:27 PM
LbulletM's Avatar
LbulletM
Never been there before. Mostly just stay in the C6 and occasionally in the C7 sections. Works in the C7 section because there are a LOT of C7 owners here. I'll try posting there. Thanks!
Old Aug 14, 2014 | 01:52 PM
extrapilot's Avatar
extrapilot
What are you trying to accomplish.
Using the right equipment and going over some videos, can lead you to getting the job done yourself, if you care to. DA polishers like Porter Cables' are very safe machines to use for polishing out the typical washing scratch's the finish will get. The key is using the correct polishes and pads, learning how to identify which polishes to use, depending how bad the finish is.
If your looking for the flattest results, ( less orange peal appearance ) which means wet sanding, leave to the pros. They need to know how much clear coat is on the car by measuring before tackling the job.
For me as my car is a DD, and I will wash the car at least once a week, I regularly detail twice a year with the buffer. That will keep the finish in great shape.
Old Aug 14, 2014 | 02:00 PM
LbulletM's Avatar
LbulletM
My car is also my DD, so it doesn't need to be showroom perfect, but it's an '07 with almost 7k miles on it, so it could definitely use something. You can see faint scratches on places, especially on the top of the rear end. I'll have to try to get a picture. If it's really hard to mess up, I might give it a try. I'm pretty DIY. I was just afraid of going through the clear coat or something.
Old Aug 14, 2014 | 02:59 PM
Ahmer's Avatar
Ahmer
EAGLE AUTO Collision near Pasadena does all my work. Ask for Craig and tell them "Ahmer w the yellow vette" sent you.
Old Aug 14, 2014 | 03:00 PM
Ahmer's Avatar
Ahmer
Eagle Collision Repair 713-910-8280
Old Aug 14, 2014 | 03:05 PM
mred_baker's Avatar
mred_baker
Try calling The Finishing Touch mobile car detailing, they are located in Spring. I have not used them yet, but a lot of people in my neighborhood have.
(832)441-6812
Old Aug 14, 2014 | 03:19 PM
MrSoftail6969's Avatar
MrSoftail6969
Cruising
Default Clarity Auto Detailing
Clarity Auto Detailing. These guys are great. None better that I have seen. They are at 6830 N. Eldridge on the west side of Houston
Old Aug 14, 2014 | 03:35 PM
LbulletM's Avatar
LbulletM
Thanks guys, I'll look into them.
Old Aug 14, 2014 | 03:53 PM
extrapilot's Avatar
extrapilot
Could be the perfect DIY type of job for you, and you have the feeling of accomplished satisfaction when you look into that glossy finish.
In using a DA polisher/buffer, it's extremely hard to "burn" through the paint. It's a very "safe" way to polish. Our clear coats are very hard also, down side is that more time is needed for deeper imperfections. But using stronger polishes and the right pad will get it done.
Do a little research online, Auto Geek is a good source, Detail Image, another, is where I get my supplies from.
It's possible to get by with just two polishes, two or three sets of pads, microfiber cleaning cloths, clay bar, detail spray, a good sealer/wax and of course a DA machine.
Tips like looking at the finish with a strong light will show hidden micro scratches, from washing, helps analyze how well you polishing job is going.
Looking to kill time and keep busy, this will do it.
Old Aug 14, 2014 | 04:23 PM
LbulletM's Avatar
LbulletM
Thanks extrapilot. I might go this route. I'll spend about the same on supplies to last a few details compared to one detail by a shop.
Old Oct 4, 2017 | 09:00 AM
GSTexas's Avatar
GSTexas
I tried using this shop and got really hosed. Owner was a real snake oil salesman. Needless to say he kept my deposit after stringing me along and giving me the runaround for weeks. Not saying they do bad work, I wouldn't know because they never did any for me, just the business and professional side of their shop is friggin horrible. My advise is to steer clear. Just my thought. I went with Dynamic Auto Works in Spring and all I can say is WOW truly amazing beyond belief. So great of a job my dropped my C5 off the next day to have it done. Customer service at it's best. Fantastic shop!!
Old Oct 4, 2017 | 09:39 AM
Jmhornz71's Avatar
Jmhornz71
I did my 08 Coupe myself and it came out great. I used polishing compound first, rinsing the applicator often. The I polished with Maguires Carnuba wax wiped it off then used a buffer car looked great. Mine has almost 130k miles on it and is Velocity Yellow Name:  DSC04513.JPG
Old Oct 5, 2017 | 07:03 AM
ben dover's Avatar
ben dover
From: When all is said and done... there is a hell of a lot more said than done. Riverside,Texas
St. Jude Donor '05 thru '26
Another vote for Clarity.
To Houston Paint Correction
