Scraping Bottom?
Old Aug 18, 2014 | 05:05 PM
Townie33's Avatar
Townie33
Default Scraping Bottom?
Have a 2012 GS which will lightly "scrape bottom" whenever I drive out of my driveway (down). Driving up is no problem, but I always get a minor/slight scrape leaving. It's something with the angle.
Suggestions????
Old Aug 18, 2014 | 05:08 PM
EVRose's Avatar
EVRose
It's just the rubber air damm. Don't worry about it. They all scrape sooner or later. It even says so in the owners manual.
Old Aug 18, 2014 | 05:11 PM
tennblkc6's Avatar
tennblkc6
yeah...I have the issue too so i'm a little worried if I install the splitter it could be worse.
Old Aug 18, 2014 | 05:13 PM
Vette_DD's Avatar
Vette_DD
Just drive slowly going over it. I've got the same problem entering and exiting the Walgreens parking lot.
Old Aug 18, 2014 | 05:21 PM
Dave S's Avatar
Dave S
Retired & lovin' it!
Try going off the end of the driveway at as sharp an angle as you can manage. There's very little clearance between the bottom of the front air dam & the ground. In any case, as others have noted, scrapping the air dam is no big deal.....just go slowly.
Old Aug 18, 2014 | 05:38 PM
HBsurfer's Avatar
HBsurfer
That rubber air dam is only $89 from a forum vendor. Cheap and easy to replace if it wears out.
Townie33's Avatar
Townie33
Thanks so much for the quick and informative input!
I have already attempted the sharp angle with no luck. And if I go any slower I will probably be going backwards!
But it is good to know it is "no big deal" and is expected.
Love this ride.
Out here (on I-15) there are some spots where the speed limit is 80 mph. Fun!!
Old Aug 18, 2014 | 05:42 PM
ZR1Cat's Avatar
ZR1Cat
Just confirming what others have said previously. Just go slow and you probably have nothing to worry about.
I love the CE cars and that Carbon Flash Metallic paint!
Old Aug 18, 2014 | 05:48 PM
Townie33's Avatar
Townie33
Thanks!
Closest thing to the BATMOBILE I could find.
To Scraping Bottom?
