2008 Victory red C6...On each side of the engine there are 4 armed what looks like aluminum metal bolted to the sides of the spark plugs. What are these called? What would you clean them with?
There is nothing connected to the spark plugs except the plug wires and they aren't bolted to the plugs.
Are you talking about the sheet metal coverings (heat shields) for the exhaust manifolds?
You'll never get an answer to your question unless folks know what you're talking about.
just when you warm up the engine, before spraying any degunker,don't touch those "armed" thingies to make sure its hot enuff.Might take awhile for your fingerprints to grow back.
