My navigation seems to be working, but on the top left side of the navigation screen it has a line crossing through the GPS symbol.
The owners manual says that means i am not receiving the satellite signal when it has the line through it, but I must be receiving the signals because its working. Has anyone else had this problem?
Thanks,
Nelson007
From: Currently somewhere in IL,IN,KY,TN,MO,AR,MS,AL, or FL
Yes, you are not recieving any GPS signals. The nav system uses inertial guidance when GPS is not available. It will appear to work but will eventually drift if you don't reestablish the GPS signal. The GPS antenna is in the rear bumper area connected to a VCIM (Vehicle Communications Interface Module) also mounted in the rear. Window tinting will sometimes block the signal. The recommended repair procedure for no GPS signal is to remove the antenna and cable from the car placing them outside. Does it work? If so the issue is window tint. If not replace the antenna. Does it work? If not replace the radio.
BTW, the GPS symbol is upper right, not top left.
Thanks for the info, i will try to check it out tomorrow.
Nelson
just wondering if the antenna is in the rear bumper then what does window tint have to do with it?
The rear hatch glass covers almost half the sky if you are trying to look up from inside the cover on the back bumper. There are 24 operational satellites in low earth orbit at any given time. 4 are needed to get a position. 12 will be below the horizon. Typically 4 will be too low to get a good signal. Block 2 more with buildings, trees, and the metal in the car and you are down to 6 left. Now block half of those with metalic window tint and you have 3 good signals but you need 4.
