Base spoiler install help
Old Aug 21, 2014 | 04:31 PM
Z51vette88's Avatar
Z51vette88
Default Base spoiler install help
Hello I just bought a new oem spoiler for my base vette. But how do I install it
Jared
Old Aug 21, 2014 | 05:04 PM
edcologne's Avatar
edcologne
obviously he's installing a different spoiler but it should give you all the info you need and more.
and then there is also the search option on the forum
Old Aug 21, 2014 | 05:17 PM
Z51vette88's Avatar
Z51vette88
Okay thanks. Im actually installing another stock one. Previous owner scratched it.
An I hate searching on my cell. An a employee offered to do it.
But thanks again :-)
Old Aug 21, 2014 | 05:26 PM
Cowboy26a's Avatar
Cowboy26a
I think it is simple. Take the two inside tail lights out. Unplug the wire to the third brake light. Using a deep well 10 mm socket remove the bolts going in from the inside tail light holes. That should be it. transfer your light to the new spoiler if needed and re-install. be careful and don't drop the nuts behind the bumper. you may have to transfer the bolts from the old spoiler to the new one. You will see how when it's off. I have a new one coming in soon and will have to do the same procedure. Watch the video in the post above. The center section should be the same as yours.
To Base spoiler install help
