eibach suspension
Old Aug 22, 2014 | 11:08 AM
billyboy47's Avatar
billyboy47
St. Jude Donor '17
Default eibach suspension
i'm thinking of upgrading the suspension on my 013 base and i was wondering if anyone on the forum has the upgraded eibach system on their car. i was told that it is the same system used on the g.s. models. true or not? i was quoted a price of $1350.00 tax included. just wondering if the upgrade would be worth the bucks. thanks for any input i recieve.
Old Aug 22, 2014 | 11:16 AM
RicK T's Avatar
RicK T
What is included?
Old Aug 22, 2014 | 12:09 PM
billyboy47's Avatar
billyboy47
St. Jude Donor '17
Originally Posted by RicK T
What is included?
upgraded springs, sway bars and bushings. i use the o.e.m. struts. your thoughts?
Old Aug 22, 2014 | 12:23 PM
el es tu's Avatar
el es tu
I have never seen that offered from them
they do sell a kit that replaces the bars and associated bushings as well as the spring adjusters, but its nowhere near 1300 (more like 300 to 400 bucks). On that kit they usually use the same image as seen for a lot of stuff so it looks like coil springs in the ad but then you see a note that its just the adjusters...
good luck
Old Aug 22, 2014 | 12:27 PM
RicK T's Avatar
RicK T
Well, I don't know anything about that specific package. Eibach has a good reputation.
But I am concerned that you said you were told it is the same system as the GS. The GS uses Z51 springs but with a Z06 rear sway bar. It is generally believed the Z06 rear bar is too much for a base car with base tires. That's not to say it doesn't work. Several here have done it but unless you're an accomplished driver it could be a problem. The stiff Z06 rear bar with base tires/wheels will tend to induce oversteer. If you aren't ready for it and know how to deal with it, might result in a crash.
So I'm just saying be sure you know what you are doing and getting into.
If you're just a typical driver who wants a better handling street car for occasional spirited driving on twisty roads, a great many here have simply changed to Z51 sway bars (about $260 from gmpartshouse.com) and Bilstein HD or Bilstein Sport shocks (about $350) and been very happy with the result.
If you tell us you are an experienced track driver and want to track the car regularly then disregard what I said.
Old Aug 22, 2014 | 06:07 PM
billyboy47's Avatar
billyboy47
St. Jude Donor '17
retired trucker and no desire to track the car. a local performance shop by me quoted the price on the eibach set up. $585 for parts and the rest labor and taxes.(7%)
Old Aug 22, 2014 | 06:43 PM
v26278's Avatar
v26278
el es tu is correct, the kit for Corvettes does not include springs. But it does include sways and new lowering bolts. The same kit includes new coils only on cars with coils from the factory. To get new springs on a Vette, you'll have to go to the more pricey coil over set up.
Eibach makes good products, I installed their progressive rate coils on a BMW and it was a big improvement in handling without sacrificing ride. But I don't know how their sway bars compare to others, for the price you might have other options, and new lowering bolts are of little use unless you want to drop the car down more than can be done on the stock bolts.
Old Aug 24, 2014 | 07:31 AM
billyboy47's Avatar
billyboy47
St. Jude Donor '17
i apologize. i thought the word "track" was truck. its hell getting old.
To eibach suspension
