427 alignment
Old Aug 25, 2014 | 09:20 PM
jversluis's Avatar
jversluis
Default 427 alignment
Anyone have alignment or premature tire wear on 427
Is 427 alignment agreesive or more street set
Old Aug 25, 2014 | 09:30 PM
Corvertible's Avatar
Corvertible
I've got just over 2K, so I'd like to know as well.
Old Aug 25, 2014 | 09:54 PM
Dano523's Avatar
Dano523
GM sets the alignment on the corvettes more aggressive (read favoring the inside corners of the tires on a flat stance since it will put the outer tires flat to the ground for the best grip on hard banking), meaning that you will wear the tires out faster if all you are doing is street driving the car.
With tires around $2K to replace, if you are only going to be DD the car and not push it, then spend the $150 to have the alignment changed to street only alignment.
Here is the Pfad specs, so print it out, and have the tech use the street spec.
http://www.pfadtracing.com/docs/camb...t-settings.pdf
Old Aug 25, 2014 | 10:09 PM
hisvett's Avatar
hisvett
St. Jude Donor '14-'15
The Pfadt street numbers are GM specs; a little too much camber for us non-performance drivers and will cause inside tire wear on the fronts. I have found that -.5 keeps the tread wear flat across the surface of the tire. I use just a touch of toe in; .065 works well....
Go for the Firestone lifetime alignment and use it once a year....cheap insurance Vs. the cost of a sent of tires.
Old Aug 26, 2014 | 12:04 PM
utownal's Avatar
utownal
I found out this information when I went to the Chevrolet Dealership to change out the very bad worn tires on my Z06.
Old Aug 26, 2014 | 04:09 PM
69L79's Avatar
69L79
From: Hamilton Square NJ, Ocean City N. J. Key Biscayne Fla.
The Pfadt street alignment was better than original specs. But, still too "aggressive". I got double the tire life than OEM. But, still only 20K on Invos. Didn't bother me because I buy new tires every 20K anyway.
Old Aug 26, 2014 | 04:17 PM
z06clif's Avatar
z06clif
They will wear out on the inside of the front tires unless you change the alignment. Set this way at the factory
Clif
Old Aug 27, 2014 | 07:37 AM
jversluis's Avatar
jversluis
picking it up at noon today and will post the alignment spec used. I left the Pfadt specs with tech but left it up to him to set. 6500 miles and tires appear to be wearing fine.
At the bash in April I asked the marketing mgr for corvette and he said 427 is set up between zo6 and GS.
Old Aug 27, 2014 | 08:17 PM
jversluis's Avatar
jversluis
Default 427 alignment update
Just got my car back from dealer. Great tech and service. Replaced steering gear(rack) and car is tighter and problem gone. Had alignment done with as close to Pfadt street alignment as possible.
front camber before:-1.1, after:-0.8 caster:7.9,toe-0.01. Tech said this was best done with out going into red zone whatever that means. But now I have a less aggressive alignment for best tire wear and street use. No pulling and tracks beautiful.
cheers
To 427 alignment
