My 2008 is at exactly 99,512 miles just brought it in for an oil change 2 weeks ago. I was told the spark plugs needed to replaced because I was approaching 100k miles. That is the only reason I could think of the light is on. If anyone could weigh in please do!!! Thanks
you probably need plugs, but also have the codes read by someone who is a tech and knowledgeable about them. it may have set a misfire code due to the plugs being worn.
Change the wires too! with that mileage it's time for tranny fluid change and coolant flush as well.
From: Currently somewhere in IL,IN,KY,TN,MO,AR,MS,AL, or FL
You're kidding, right? There are 516 major errors that the car can specifically identify, set codes, and turn the light on to tell you that something is wrong and you want us to just pick one at random with no other information other than mileage and the oil was changed 2 weeks ago? OK, I'll play the game. I choose P0668 Transmission Control Module Temperature Sensor Circuit Low Voltage. Do I win?
Go to one of the major parts stores and have them read the codes for free and tell us which of the 516 you have and we can be a lot more helpful. Otherwise we can guess for a long time without giving you anything useful. It could be something trivial like the gas cap (common) or the engine on the verge of self destructing.
Don't understand these posts of "Check engine light on...what could it be?'" We need a "This thread is worthless without an actual trouble code posted" pic.
When the little AutoZone girl didn't clear my DTC as requested, I spent a whopping 20 bucks on my own CAN OBD reader.
Talked to my guy earlier this evening, didn't get the exact code from him but he said the light wasn't anything from a tune up stand point. However, had to do with the evap. If anyone could enlighten me it would be greatly appreciated.
You need the exact code. There is an evap code for a small leak, and a code for a large leak, and probably others as well. A while back I got the CEL on, it stayed on for a while but the car ran fine, so I picked up a scan tool, read the code p0442 for small leak, cleared the code and it never came back. Scan tools are handy to have aroung the garage.
Hello....it's very simple. Go to any auto parts store like Advance Auto, PEP Boys or whoever is local to you. Ask them to plug in their code reader (which they will all do for free) & see what specific error code or codes is causing the "Check Engine Light" to come on. It could be something simple like a loose gas cap or something difficult like a bad ECM. Without the specific code(s), you're wasting your time asking the question.
EDIT - based on your "EVAP" code:
loose or bad gas cap <-- try this first, buy a new cap or lube the seal on the old one.
vacuum leak
charcoal canister full of fuel <-- do you regularly top off when fueling up?
Gasoline expands with heat and loses volume with cool. In a closed system this creates pressure and vacuum in the airspace above it. Old cars use to vent that to the atmosphere, but that is no longer allowed. Even my new lawnmower has evap canister.
A typical system consists of a small canister full of charcoal, valves, hoses, vents in the fuel lines and a sealed fuel tank cap. When fuel evaporates inside the gas tank, the excess vapors are transferred to the charcoal canister. They're stored there until they can safely be transferred back to the engine to be burned with the normal air-fuel mixture.
Your code says the system is leaking somewhere.
One out of 516 is bad odds, but loose gas cap is the most likely, given no other info. The light will not go off right after fixing gas cap...it will take a few start/run cycles.
