headlights on my 2007 atomic orange have become bad on the inside. had two pros try to buff lenses, they said the inside of the lens is bad. can the lenses be replaced, or must i replace a complete unit? help! thank you
Reason: mispelled word
If you do a search on "headlamp lens replacement" on this forum, or "corvette c6 headlight replacement" on You Tube, there are all sorts of postings and videos.
RLSebring on this forum sells replacement lens, or he can do the replacement for you. Looks like a fair amount of work, but it appears to be the type of task where if you're patient, it can be done.
If you really want your headlights to be second to none give mike from Vettestetics a call. He has some shots of orange Vettes on his site with his product. I couldn't be happier with mine.
Replacing the lens yourself is not that difficult if your willing to invest the time. I was in the same boat as you, were the lens were pitted and and turned opaque above the turn signal bulbs. Lots of suggestions/help here on the boards.
From: Pensacola Florida GO GATORS!!! www.rlsebring.com www.c6c7vette.com
St. Jude Donor '17
