run flat tires
Old Sep 29, 2014 | 12:59 PM
tankengine's Avatar
tankengine
Water Well Doctor
Default run flat tires
I know more than I do so here goes. did any of the C6s come with run flat tires?
Tankengine
Old Sep 29, 2014 | 01:02 PM
EVRose's Avatar
EVRose
They ALL do since there is no spare.
Old Sep 29, 2014 | 01:39 PM
tankengine's Avatar
tankengine
Water Well Doctor
thank you,
so what is the construction of a run flat tire compared to regular tires?
and I'll bet they're more expensive.
Old Sep 29, 2014 | 02:14 PM
Richard Ames's Avatar
Richard Ames
$400 to $600 more for a set depending on brand. They have very stiff sidewalls compared to non run flats and wear faster because they are less compliant than non run flats.
Old Sep 29, 2014 | 04:47 PM
Huskerman's Avatar
Huskerman
2021 C6 of the Year Finalist - Modified
The newer breed of runflats are not as stiff as the old ones were but they still have to have a sidewall you can drive on for 50 to 100 miles with no air in the tire. I have a set of Bridgestone Potenza RFT's on my Grand Sport with about 15K on them and they look good.....I don't think they ride bad and I want to be able to keep going if I do get a flat......
Old Sep 29, 2014 | 06:27 PM
bucwheat's Avatar
bucwheat
No run flats on the ZO6 or ZR1.
Old Sep 29, 2014 | 06:41 PM
budgreen3564's Avatar
budgreen3564
Wrong!
Old Sep 29, 2014 | 08:38 PM
gongo's Avatar
gongo
I ditched my run flats for a set of Bridgestone Potenza S-04 Pole Position non-run flat summer tires. The ride is much better, quieter on the highway, and more grip on the track. I keep some tire slime and a pump in the trunk just in case but I'd call AAA first if I got a flat.
Old Sep 29, 2014 | 09:02 PM
owc6's Avatar
owc6
From the Owner's Manual:
"The valve stems on your run-flat tires have sensors that are part of the Tire Pressure Monitor System (TPMS). See Tire Pressure Monitor System on page 5-73. These sensors contain batteries which are designed to last
for 10 years under normal driving conditions. See your dealer/retailer if you ever need to have a wheel replaced, or if the sensors ever need replacement.
Notice: Using liquid sealants can damage the tire valves and tire pressure monitor sensors in the vehicle’s run-flat tires. This damage would not be covered by warranty. Do not use liquid sealants
Warranty to the TPMS aside, I've heard it is a bear to clean the inside of the tires/wheels/sensors, and will cost a pretty penny to do so.
Old Sep 29, 2014 | 09:12 PM
gongo's Avatar
gongo
Which is why I said I would call a tow truck first. The tire slime is in case I can't get one out to me. I'm out in Utah, it's pretty easy to get stuck far from civilization very quickly.
Old Sep 29, 2014 | 09:18 PM
owc6's Avatar
owc6
My post was for those who haven't done their research as well as you.
Despite what the can says, it is not TPMS safe. Only to be used in extreme emergency with eyes wide open on the potential issues, RF or not.
Old Sep 30, 2014 | 12:16 AM
ohfiver's Avatar
ohfiver
Default R/f
R/Fs for me but a better brand than the stockers!
Old Sep 30, 2014 | 05:00 PM
Seadawg's Avatar
Seadawg
The Bridgestone Potenza Pole Position Run Flats don't wear any faster... I got over 30,000 miles out of my first set, on a Grand Sport, and that included a lot of spirited driving and some track time too.
Old Sep 30, 2014 | 05:16 PM
windyC6's Avatar
windyC6
HUH ??....if compliant as it is applied here means that in the beginning that most runflats were high-po tires with a softer tread compound made for better cornering....then yes....that is why they don't last as long. For us common folk....The run flats used/use a much softer compound for better grip in the twisties.....softer compound = shorter tread life.
To run flat tires
