New member here. I was wondering if someone else had the same problem as me. The spoiler plastic under the 3rd brake light bows out. I'm not sure if there is something to hold it in since I have not removed the spoiler. This is on a 2011 coupe. Thanks.
Typical from an aftermarket ZR1 spoiler. Supposedly the OEM spoiler does not do that. There are also other spoilers out there that have more material in that area. I like the ZR1 spoiler but have not bought one because of this issue.
Take out the taillights, loosen slightly the nuts on the spoiler, tuck the strip below the taillight back under the taillight and snug the bolts back down.
One or more of the nuts might already be loose.
Tension from the spoiler and 3rd brake light keeps that strip tucked underneath.
Very common issue on aftermarket spoilers as the strip is not as wide or thick as the OEM unit.
It will be easier to do on a warm to hot day as the spoiler is made from ABS and will soften up little and accommodate your movement - but it can be done any day.
