rattling when accelerating?
Old Oct 7, 2014 | 01:55 PM
david2613d's Avatar
david2613d
Default rattling when accelerating?
Hey guys,
I have a strange rattling noise going on when i accelerate sometimes, it almost sounds like somethings rolling around under or inside the car.. i took alook but couldnt find a thing.
Thanks,
David
Old Oct 7, 2014 | 03:29 PM
subfloor@centurytrans's Avatar
Supporting Vendor
2024 C6 of the Year Finalist - Modified
2020 Corvette of the Year Finalist (track prepared)
2019 C6 of Year Winner (track prepared)
Originally Posted by david2613d
Hey guys,
Thanks,
David
It's called engine knock and usually means you're either not running good gas or the engine tune is out of whack for the fuel you are using, usually from too much timing.
Old Oct 7, 2014 | 04:02 PM
david2613d's Avatar
david2613d
I don't think its engine knock, it sounds like its coming from the back of the car, I've recently had my wheel bearings replaced and shifter linkage cable.. I don't know what to think.
Old Oct 7, 2014 | 07:07 PM
Huskerman's Avatar
Huskerman
2021 C6 of the Year Finalist - Modified
I would take it back to the shop and have them check it out.....something ain't right...
Old Oct 7, 2014 | 07:12 PM
LedZepper's Avatar
LedZepper
It may be a loose exhaust line hanger. It sounds similar to a rattle I had, and that was the problem. Good luck!
Old Oct 7, 2014 | 07:25 PM
Huskerman's Avatar
Huskerman
Is your car a 6M or and auto.....?
Old Oct 7, 2014 | 10:38 PM
Chevy Cust Svc's Avatar
Chevy Cust Svc
Hey guys,
Thanks,
David
David,
Sorry that your 'Vette has an acceleration rattle. I understand the displeasure when dealing with a matter like this. Although you're seeking opinions from others, I'd be happy to communicate your concerns with the Customer Experience Managers (CEM) at your GM dealer of choice. Please know that you're welcome to message us privately if you would like to discuss this further, or if you simply want this matter documented.
William R.
Chevrolet Customer Care
Old Oct 9, 2014 | 04:00 PM
david2613d's Avatar
david2613d
[QUOTE=Chevy Cust Svc;1587995010]David,
ill send you a pm
Old Oct 9, 2014 | 04:38 PM
unixcorn's Avatar
unixcorn
David, why don't you post the year, mileage, transmission type (A6 or M6) and any other pertinent information you think could be helpful to diagnosing the problem.
If the car is higher mileage, it could be the torque tube bearings. Without knowing more particulars, it's a shot in the dark. These guys are pretty good at guessing the right thing when they have more information.
Old Oct 9, 2014 | 04:42 PM
david2613d's Avatar
david2613d
yeah these guys really know the ins and outs of the c6, hopefully I will one day as well, and thanks ill look into the torque tubes.
Car Info:
-2008.
-A6.
-90K MILES.
-Completely stock.
Old Oct 9, 2014 | 05:04 PM
JJGOLD's Avatar
JJGOLD
Default Rear of car rattle
If you have the NPP exhaust, it could be the solenoids which switch the exhaust opening at 3500 rpms.
Old Oct 9, 2014 | 06:03 PM
HOXXOH's Avatar
HOXXOH
Is this at WOT or just brisker than the rest of everyday traffic? Is there a particular RPM range where it's most noticeable? Did this start all of a sudden or has it been there for a while and getting worse? Can you describe the noise intensity, pitch/tone, and frequency in relation to another well known common noise?
It's helps to give every possible bit of information initially, rather than in bits and pieces.
To rattling when accelerating?
