I find myself replacing tires when I hit a puddle and the car hydroplanes, I start shopping.
It is usually around the 30K miles mark.
I am on my third set of Michelin's.
Not really true about the fronts wearing out faster.
My fronts could go another 30K, the rears are what my car wears out.
My driving is about 90% highway at 70mph+. Never tracked, never raced, sometimes I will take off from a light.
I'm at 9,5XX miles on my 2013 Grand Sport. The rear tires are close to the wear bars @ approximately 4/32 and the fronts have even wear across the tire with approximately 6/32 remaining. Isn't this supposed to be the exact opposite?
My 2012 Grand sport was the same as yours at 7500 miles. Replaced the OEM with Michelin Super Sport non run flats. Rides like it should now.
I was thinking in terms of how many miles one gets if one does not race the car, although I did not actually say "miles" in the question. That seemed fairly obvious to me, although a few really insightful folks just said to change them when they wear out. Well, duh. Anyone that can afford a Corvette can figure that out. The posts that specified miles driven (without racing, or burnouts) were useful. Thanks.
As soon as I bought the car. those run flats are crap.
As far as an actual mileage? Impossible to judge based on that metric. Driving styles, roads, temperatures, alignment specs, etc. People here have reported anywhere from 8000 to 24000+ on the factory Goodyears.
What most C6 pilots do is:
When the rear tires are due to be replaced, they do their best to destroy the power
train, and end up replacing it along with the rear tires.
Miles is a really poor measure of tire life unless you indicate the specific tire and general usage.
OEM tires on Z51 optioned cars driven mostly in town are dead in the 10K to 15K range, while OEM tires on base and F55 optioned cars easily top 30K on the highway. Even though the tire size is identical, the compounds are different and wear at significantly different rates.
I got 34K on my OEM GY's (F55 car) and had 4/32 remaining when I changed to Invos. It was mostly highway driving, but I had nearly 100 passes at the drag strip too.
You'd be hard pressed to find someone who managed to get 20K with the OEM tires supplied on a Z51 optioned car.
You may have missed it, but I did say street driving, no racing or winter environments. Just wondering what others have experienced with their tires.
Replace when it is obvious that they need replacing. Replacement has more to do with remaining tread etc than miles. Some can go a lot longer, or less, than others based on tire type, driving habits of the driver, keeping tire properly inflated etc.
"Check your vehicle owner’s manual for specific recommendations for tire replacement for your vehicle. Some vehicle manufacturers recommend six years, some tire manufacturers recommend 10 years as the maximum service life for tires, including spares."
Other than at the legal tread depth of 3/32nd, I notice an increase in road noise as well as the wandering as tires age. They seem fine up to a point (which differs on cars and tuning), then I start to notice the more pronounced wandering when driving on less than perfect roads.
Also, a worn pair will hydroplane with less water on the roadway. I do drive mine daily and have been out in some moderate rain that was enough to feel the front end not responding to turning inputs so I slowed down from highway speeds.
There is an event in early November where I might sign up to track my car. I will hold off until after this event (rain or shine) to replace my tires. I still have more than the legal tread depth, but these are the stock Goodyear F1 Runflats. I bought the car used with 23k and I'm now at 36k after 6 months. Previous owner might have replaced them at some point with the OEM tire.
At the end of the day, if the tires are legal, it's whenever you want to replace them.
From: Hamilton Square NJ, Ocean City N. J. Key Biscayne Fla.
Its a high performance sports car. Only as good/safe as its tires. So, every 20K I buy new tires. Only exception were the OEMs which were shot at 9K. New tires gives the Car a fresh feel. IMHO, its not about seeing the wear bars.
I got 34K on my OEM GY's (F55 car) and had 4/32 remaining when I changed to Invos. It was mostly highway driving, but I had nearly 100 passes at the drag strip too. You'd be hard pressed to find someone who managed to get 20K with the OEM tires supplied on a Z51 optioned car.
Actually, I managed 22,000 miles on my OEM Goodyears, 2008 Z51. I drive "spiritedly" but no track time, mostly freeway and around town. Replaced with Michelin PS2 ZP's. Got 30,000 miles on those, replaced with the same, now with a little over 31,000 miles.
My fronts always seem to wear a little more than my rears. PFADT "performance street"" alignment specs.
