Crossover pipe
Old Oct 10, 2014 | 10:12 PM
wilson7's Avatar
wilson7
8th Gear
Default Crossover pipe
2006 std 6 speed. I had the tank out. (Right side tank) New sending unit in. Tank back in place. I am having difficulty getting the clamp ring seated onto the tank. The crossover pipe is seated to where the expanded part of the pipe is flush against the tank. When I took the pipe off I could not see how far in the pipe was. It feels like all internal hoses line up. Can someone tell me how far the crossover pipe goes into the tank?
Old Oct 11, 2014 | 12:06 PM
wilson7's Avatar
wilson7
8th Gear
I must mot have it aligned correctly! I have taken the tank back out and everything looks correct.
Old Oct 11, 2014 | 03:31 PM
wilson7's Avatar
wilson7
8th Gear
I had It aligned correctly! I had left the left tank sagging so that when I removed the crossover pipe it had some room to move. To put the pipe all the way back in I had to raise the left tank back to the proper position. The pipe then went right on in. No cussing but a lot of praying! I might not have gotten my answer from the forum but hopefully I can help someone else. Have a great day!
To Crossover pipe
