Hot Cockpit
Old Oct 11, 2014 | 11:21 AM
travlnman's Avatar
travlnman
4th Gear
Default Hot Cockpit
I am a new corvette owner. Proud owner of 2013 NRB GS. My question,does anyone have information on a insulating kit for the car, especially the center console. My leg from my foot too just above the knee can feel the heat. Most notable in heavy traffic and extended trips. Any info appreciated.
Old Oct 11, 2014 | 11:31 AM
Tropicana's Avatar
Tropicana
I've noticed that too. The first order of business is to press the outside-air circulation button twice (light on) so hot air isn't pushed in but still, it feels like the heater is on in my car.
I know there's a tunnel insulation kit available and when I finally do my audio install, I'm going to insulate the whole area since I'll have the seats and center console out.
Old Oct 11, 2014 | 11:33 AM
unixcorn's Avatar
unixcorn
There are several forum vendors that offer insulation kits. The kits come with pre-cut insulation pieces. The downside is you need to remove most of the interior to do the installation.
Here's a link to one of them;
https://www.corvetteforum.com/forums...5-shipped.html
Old Oct 11, 2014 | 11:38 AM
4SUMERZ's Avatar
4SUMERZ
If you just want to lessen the heat from the center console area.
I've installed the Exotic Vette insulation kit, which is 3/16" foam sandwiched between outside layer of aluminum foil.
It definitely works at cutting down the heat from that area, including the center console storage compartment.
It doesn't eliminate the heat, but it makes it much more manageable.
Prior to using the Exotic vette material, the A/C ducting insulation
(bubble aluminum foil) works almost, if not just as good, for a lot less $$. It can be bought at home hardware locations (Lowe's, Home Depot, etc)
I think the best overall solution is to install the insulated tunnel plate under the vehicle, but it's a lot more work, and much more $$.
Old Oct 11, 2014 | 09:52 PM
Patsgarage's Avatar
Patsgarage
When I changed out the stock shifter for a MGW I insulated the tunnel with a roll of Dynamat. All I had to remove was the center console, which took all of 5-10 mins. I just covered the top of the tunnel and down the sides and it made a huge improvement in heat and noise. Total cost for the roll was around $30-40, and it took less than an hour from start to finish to do the job.
Old Oct 11, 2014 | 10:03 PM
wrh3's Avatar
wrh3
You could use the same thing they use on the C7, I have some but have not installed it yet:
http://www.buyaerogel.com/product/py...m-cut-to-size/
Here is where they talk about it in the C7, last paragraph:
https://autos.yahoo.com/blogs/motora...154747632.html
I have used heat shields on past cars made with Aerogel, it works pretty well.
Old Oct 11, 2014 | 10:11 PM
Stickshiftsteve's Avatar
Stickshiftsteve
Why have I never noticed this problem?
Old Oct 11, 2014 | 11:02 PM
Huskerman's Avatar
Huskerman
2021 C6 of the Year Finalist - Modified
.....the 12's and 13's added a second set of cats that sit right under the console....which makes much heat.....don't know why they did it.....my 10 runs cool as a cucumber because it does not have those cats.....insulation or get rid of the cats is the cure......
Old Oct 11, 2014 | 11:14 PM
Red12's Avatar
Red12
Mine`s pretty hot too. Has any one tried that insulated blanket that wraps around the pipes? I saw it advertised for around $300.
Old Oct 11, 2014 | 11:44 PM
Dano523's Avatar
Dano523
Ditto, most of the heat is caused by the exhaust pipes transfering heat up the torque tunnel area through the cover.
The quickest fix for starts is to isolate the tunnel plate, and for the few extras dollars, the thicker plates that are isolated, help to stiffen up the car as well.
Old Oct 12, 2014 | 12:18 AM
mlsins's Avatar
mlsins
Old Oct 12, 2014 | 07:35 AM
blue max's Avatar
blue max
There is a new product from Z/COOL(I think they are a forum vendor) that is easier and less expensive than replacing the entire tunnel plate. the insulation is simply attached to the existing plate with a high temp pressure sensitive adhesive.It has been on my 13 for some time now and no loss of adhesion.
I have done it both ways and this is a piece of cake.
Old Oct 12, 2014 | 07:53 AM
RoadkingC6's Avatar
RoadkingC6
Does this install from underneath the car or do you have to remove the center console and install from the top ?
Old Oct 12, 2014 | 08:05 AM
BillWTX's Avatar
BillWTX
Sounds like he's referri to the plate underneath
Old Oct 12, 2014 | 09:13 AM
Dano523's Avatar
Dano523
To the bottom of the existing tunnel plate,
https://www.corvetteforum.com/forums...at-shield.html
As for the 1/4" insolated plates that help to stiffen the car as well,
http://www.eliteengineeringusa.com/1...h-thermal-abs/
http://www.zip-corvette.com/catalog/...-tunnel-plate/
As for ordering it from zip, you can have them throw in some bushing poly bushing shims as well, since bank that the ones in your lower shifter housing are long over due for replacement.
http://www.zip-corvette.com/catalog/...sing-bushings/
Old Oct 12, 2014 | 10:17 AM
travlnman's Avatar
travlnman
4th Gear
Default Z/ cool
[QUOTE=blue max;1588024009]There is a new product from Z/COOL(I think they are a forum vendor) that is easier and less expensive than replacing the entire tunnel plate. the insulation is simply attached to the existing plate with a high temp pressure sensitive adhesive.It has been on my 13 for some time now and no loss of adhesion.
Thanks, I will look into to z cool.
Old Oct 12, 2014 | 10:40 AM
Mikado463's Avatar
Mikado463
yep replace the mid pipe with a non catted version. Not an issue for emission testing that's done via OBD II (no sensors post these cats), if your State uses a tailpipe 'sniffer' that could be a different story
To Hot Cockpit
Old Oct 12, 2014 | 12:46 PM
blue max's Avatar
blue max
[QUOTE=RoadkingC6;1588024052]Does this install from underneath the car or do you have to remove the center console and install from the top ?[/QUOte
Underneath the car
Old Oct 12, 2014 | 03:10 PM
TerryL's Avatar
TerryL
St. Jude Donor '17
GMInc and Corvette R&D in particular SAUK! They should have insulated the bottom from the dashboard throughout the tunnel all the way back to the taillights before selling any cars. Everything/anything we can do 'helps' but w/o proper insulating underneath, the heat will still rise to the cabin and fry our leg and anything in the console or the trunk. I wonder if the Corvette model was given to the Cadillac division for production would eliminate this overlooked or ignored heat problem in an otherwise fine sports touring car.
Old Oct 13, 2014 | 02:51 PM
Marc@Vettenuts.net's Avatar
Marc@Vettenuts.net
Supporting Vendor
St. Jude Donor '11
We have found our Premium Kit all but eliminates heat while dropping cabin noise 10 to 14db depending on road surface. More info located here: C5 Insulation Kits
