Somebody please help me. I put drag radial on my car a 2008 c6 and my active handling will not turn off. I even tried to hold the traction button down nothing. Is there anyway to bypass this and completely turn it off?
yep...gotta have them either in the tires or there was some other trick where someone had them in a pressurized container in the car or something to that nature.
Can you turn off TC with your street tires on the car?
The TPMS issue isn't always a problem with drag racers because the system resets at each restart of the car and doesn't engage before you've had time to make your run.
The tire diameter change, if it's too radical and doesn't retain the OEM front-to-back tire diameter ratio within about 5-6%, then that will trigger AH.
