Starter Button
Old Oct 16, 2014 | 07:46 AM
racerbug's Avatar
racerbug
Default Starter Button
Hi Guy, Here is what I have .I have a 2006 when I turn of the car sometimes it will go to Acc. and will not turn off. I have to start and stop the car a few times then it will go to the stop mode. Any ideas?
Old Oct 16, 2014 | 08:57 AM
FortMorganAl's Avatar
FortMorganAl
From: Currently somewhere in IL,IN,KY,TN,MO,AR,MS,AL, or FL
Are you holding the Stop/Acc/Run mode side? A simple quick push is all you should need. If you are not holding it then I'm guessing you are getting a "double click" on the button because the button is corroded or dirty.
Old Oct 16, 2014 | 09:13 AM
unixcorn's Avatar
unixcorn
Old Oct 16, 2014 | 09:32 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
When FMA refers to the "side" of the switch, he really means "Top side" or "Bottom side".
The switch looks like it has a left and right panel, but it's just a rocker switch with some fancy markings and lights.
As mentioned, holding it in the "Off" position a moment too long, will cause it to go into "Acc".
EDIT:
Our 2006 required only a quick tap on the switch to shut down, our current 2009 requires I hold the switch for just a bit longer.
Old Oct 16, 2014 | 09:42 PM
VET4LES's Avatar
VET4LES
EDIT:
It's just a rocker switch.
Old Oct 17, 2014 | 09:45 AM
dcarter0001's Avatar
dcarter0001
If the switch is the problem, a new one is fairly cheap and changing it out is a easy DIY.
Old Oct 17, 2014 | 02:00 PM
cclive's Avatar
cclive
I agree with the above and would bet that you are holding the bottom of the button a bit too long. Also I agree that the button is a simple rocker switch with only a top and bottom...there is no side to side switch. It is a simple ON-OFF-ON momentary switch.
There should be no reason to have to restart the car in order to get it out of ACC mode, a simple second push on the bottom of the button should turn ACC off.
To Starter Button
