2005 squeaking noise.....
Old Oct 20, 2014 | 06:39 PM
mikey48240's Avatar
mikey48240
6th Gear
Default 2005 squeaking noise.....
Hi I'm new here and looking at purchasing my first Corvette, it's a 2005 with the Z51 package with 94,000 miles for $18,500, it's fully loaded minus navigation. I took it for a test drive and drove like a vette should but rolled the windows down to listen and after breaking I'd get back up to speed and I'd hear a squeaking noise coming from the what sounded like the rear of the car. Any ideas of what it could be? Also what do I need to be on the look out for with a car with this many miles? Thank you
Old Oct 20, 2014 | 06:42 PM
ProfessorDeath's Avatar
ProfessorDeath
St. Jude Donor '13-'14
Squeaking? Maybe a bad shock or spring? You didn't notice it inside the car?
Old Oct 20, 2014 | 06:46 PM
ExRedRacer's Avatar
ExRedRacer
St. Jude Donor '05-'06-'07-'08-'09, '14-'15-'16-'17-'18
Maybe the end links need replacing. It's a relatively easy and inexpensive fix...$35/each.
mikey48240's Avatar
mikey48240
6th Gear
No I could tell hear it inside the car, and the sound just didn't start then stop, it went on for a block or two then stopped.
Old Oct 20, 2014 | 06:47 PM
mikey48240's Avatar
mikey48240
6th Gear
I ran a carfax and no issues, it's on the 3rd owner though
Old Oct 20, 2014 | 06:49 PM
mikey48240's Avatar
mikey48240
6th Gear
http://denver.craigslist.org/cto/4696168875.html
Old Oct 20, 2014 | 07:37 PM
ProfessorDeath
End Links cause more of a jittery clunk than a squeak, but possible. I would wager suspension components in need of a bit of TLC.
Old Oct 20, 2014 | 11:39 PM
bobeast's Avatar
bobeast
My guess would be dried out sway bar bushings. Cheap and easy to replace.
Old Oct 21, 2014 | 12:57 AM
4SUMERZ's Avatar
4SUMERZ
Ditto....normally squeaks are caused by rubber components ie: Sway bar bushings, shock bushings, etc. or plastic pieces rubbing against each other
Try spraying WD40 on those sway bar bushings and see if it stops the squeaking temporarily.
Old Oct 21, 2014 | 01:18 AM
mikey48240's Avatar
mikey48240
6th Gear
I went and drove it again tonight just to double check and it sounds like metal on metal. I'm passing on it. I just don't want to take the risk of something major. I also ran the car for a little while and pulled the dip stick to the oil and it smelled a little burnt.
Old Oct 21, 2014 | 11:32 AM
tennblkc6's Avatar
tennblkc6
good...I think you are doing the right thing. there's plenty more out there. good luck!
Old Oct 21, 2014 | 11:56 AM
ExRedRacer's Avatar
ExRedRacer
Good decision. There are plenty of well-cared for Vettes out there...you just have to be a little patient.
Happy hunting!
Old Oct 21, 2014 | 12:19 PM
mikey48240's Avatar
mikey48240
6th Gear
Besides my current ride is a 2014 Camaro spring edition fully loaded but missing the power of that LS2 motor.
To 2005 squeaking noise.....
