Winter storage question - Window
Old Oct 25, 2014 | 08:30 PM
NHskier's Avatar
NHskier
Default Winter storage question - Window
Hi all,
I'm getting ready to put my new-to-me 2005 convertible away for the winter later next month, so getting my act together now in preparation. I may be overthinking this, but it's my first 'Vette and I'd rather be sure about things.
I've read through a few checklists and know about using Sta-Bil in the gas, increasing tire pressure, using Damp-rid, moth ***** to keep mice away, bought a good cover, etc. I will be storing the car in a storage unit with no access to electricity, so will be disconnecting the battery.
I am assuming I should leave the hood fully closed and latched. If that's the case, come Spring I will need to open the driver side door using the release inside the trunk. As part of the storage routine next month, should I try to keep the drivers window down a bit to be able to open the door in the Spring? If so, would I: (1) with the door open, drop the window a 1/2 inch or so, (2) disconnect the battery, (3) close the door?
Should I put some foam weatherstripping or something in the gap between the window and roof channel?
NHskier
Old Oct 25, 2014 | 08:37 PM
One Kick's Avatar
One Kick
Send me a pm, I'm in NH also and just putting mine away and would be more than happy to assist you.
Old Oct 25, 2014 | 08:41 PM
MidYearRoadster's Avatar
MidYearRoadster
moth ***** wont help you much...I have heard and used Mint and it works at keeping the little critters away...get some mint shredd it and spread it around the entrance of your unit...also make up a liquid mixture of mint and water and spray it all over the place....dont leave your battery in the car...take it out and keep it in a place where it wont freeze..good luck
Old Oct 25, 2014 | 09:17 PM
saplumr's Avatar
saplumr
If you use stabil make sure it's for ethanol or better yet move to seafoam (make sure it's mixed throughout the fuel tank and system) and leave the windows up. I agree with midyear about the battery.
Old Oct 25, 2014 | 09:18 PM
1968swbbigblock's Avatar
1968swbbigblock
I would leave the windows down and the hood unlatched
Buy some mouse traps - all the wives tales in the world might or might not work but a rodent still wants to eat.
Your biggest threat will be up through the 2-3rd hard frost.
Check and reload as needed.
I put bounce sheets in my car last year - its also supposed to be a deterent - no mice and my car smelled really nice this spring ;0
Old Oct 26, 2014 | 05:56 AM
jackcasual's Avatar
jackcasual
09 Vert. I just stored mine in my garage. I don't have a battery tender, but do have a battery charger that charges at 2 or 10 amps. I remove battery and place in house. I charge battery at 2 amps every 5-6 weeks thru out winter. I have an outdoor cover. I leave windows up and hood unlatched so I don't have to go thru trunk. You will have to re-index windows when out of storage. I use stabil, change oil, clean air and cabin filters, clean inside, wax, add air to tires, change clutch fluid, wait for spring!
Old Oct 26, 2014 | 08:53 AM
FortMorganAl's Avatar
FortMorganAl
From: Currently somewhere in IL,IN,KY,TN,MO,AR,MS,AL, or FL
As others have said, take the battery home and keep it on a tender/maintainer 24/7. A battery will discharge even when disconnected and a frozen discharged battery will crack and then you have real problems. If you let it self discharge for 5 months it is going to be significantly damaged.
I would check to make sure the key works (some don't ) and then seal the car tight. No reason to leave it open to collect dust when you have a key to open it next year.
Old Oct 26, 2014 | 02:19 PM
JShocik's Avatar
JShocik
Since you're storing it inside, why the cover? It gives mice a place to "hibernate"! And they could destroy the cover. Leave it uncovered, you'll wash it in the spring. For added insurance so mice won't get in the car, place some D-Con bait traps around outside the car . This gives them an easy food source, paying attention to the food instead of the car. They'll go back to their nest ( hopefully not in the cover), eat, & die , leaving the car alone.
Old Oct 26, 2014 | 02:34 PM
USA1 427's Avatar
USA1 427
I've found that Bounty dryer sheets work great at keeping rodents away. A couple in the motor, car, and under the car. I've read (never done) that you can put tennis ***** in the tailpipes to keep them out too. Never had any issues with mice since I've been using the sheets.
Now......are you confused yet?
Old Oct 26, 2014 | 02:37 PM
Bruze's Avatar
Bruze
Originally Posted by NHskier
Hi all,
NHskier
I don't see any reason why you can't leave the hood unlatched. It won't make any difference to any potential rodents, but you will have easy access in the spring to put the battery back in without worrying about getting inside to open the hood via opening the hatch with the key, leaving the windows open, etc.
Old Oct 26, 2014 | 02:42 PM
Bruze's Avatar
Bruze
Or steel wool, and I saw an aftermarket company that actually sells some C6 custom-made plastic(?) plugs for this purpose.
Old Oct 26, 2014 | 03:13 PM
saplumr's Avatar
saplumr
Keeps the dust and junk off and helps cushion IF something were to bump it. When mine's parked...it's covered. Always has been and always will be.
Old Oct 26, 2014 | 05:18 PM
NHskier's Avatar
NHskier
Thanks for all the recommendations and suggestions!
I hadn't planned on removing the battery, just being sure it was fully charged before disconnecting. Boats are stored at area marinas this way and don't have problems. Maybe I should rethink this ...
Had thought it would be better to keep the hood latched in case of critters, but I suppose if they're going to get in it wouldn't be that way, anyway. And that does make it simpler in the spring.
i've read about moth *****, downy sheets, and now mint spray. Sure wish there was a clear this-always-works solution. Good tip on adding some traps and checking early on.
NHskier
Old Oct 26, 2014 | 05:43 PM
Bruze's Avatar
Bruze
I agree with what Ft Morgan Al said above regarding batteries. Ideally? -- keep it warm and charged, but do NOT store it directly on a concrete floor.
NHskier
Here's the "truth" about mothballs (it MUST be true, I read it on the internet ):
According to a pest removal expert, mothballs may very well prevent mice from moving into an area, but once they are established, the addition of mothballs will NOT drive them out.
Sounds reasonable to me.
Old Oct 26, 2014 | 06:17 PM
saplumr's Avatar
saplumr
NHskier
Wouldn't matter if the hood was latched or left unlatched. Critters usually crawl in from under the car.
Old Oct 26, 2014 | 10:49 PM
USA1 427's Avatar
USA1 427
As far as the latched hood........if your car doors are going to be locked then latch your hood as well unless you absolutely trust that nobody can ever get into that storage unit and lift your hood to steal parts. We recently had an instance in our town where some kids broke into a storage unit, got the keys to a Vette, took it out, and destroyed it.
Old Oct 27, 2014 | 10:05 PM
NHskier's Avatar
NHskier
Guess I'll add some traps to the list.
NHskier
To Winter storage question - Window
