* * * * DANGER Fuel Leaks - SAFETY RECALL * * * *
#61
Mine does it and I never add after it clicks off. Always has a fuel smell.
#62
I get what you are saying. I haven't over filled the tank. It's the dripping noise plus the smell of fuel that worries me. It smells like gas even with half to1/4 tank and the dripping onsomething hot sound.
#63
Mine only dose it right after filling it. It is gone next time I drive it. But it is bad inside the car right after I fill it. Unless the top is down then I do not smell it.
#64
Makes me wonder in your case at least, if maybe it may be leaking from gas cap to gas tank? Just guessing. Hope it is nothing. I'll find out about mine friday. Hope i'ts what l think after reading this thread just because I have the warranty. But either way just want it to be right and to know that it's right and safe. No worries ya know.
#65
I was woundering if everyone that gets the smell is using E 10 or E 85 fuel?
My 2008 is a stinker if it is full or empty.More smell when tanks are full but they smell all the way down to empty .I though it was a gas cap so I replaced it knowing if the cap is bad usually it will throw a light or the car would run like crap.Does anyone have pics or the tank out of the car to where you can see where it is leaking,for those that have had it repaired?
#66
The other issue no one has talked about is re-occurrence.
Even after GM does the repair and replaces the fuel pump, as far as I know, they are replacing it with the exact same pump with the same part number. So this means a few years down the road, you could have to repeat this whole nightmare all over again.
Here is a photo showing how the gas runs down the back side of the fuel tank, right next to the exhaust. You can see the stain on the tank.
Here is a photo of the cracks in the fuel pump that are causing the leak.
#67
I went out to my 07 and looked under the car just in front of driver side rear wheel to see the bottom corner of the fuel tank and saw the gas trail on the outside of the tank.so it is definitely leaking. Droping car off at the dealership in the morning. Made a appointment yesterday. I'm a bit nervous about taking it to the dealership. Wish me luck. Will let you guys know what happens.
Olnavy (03-01-2019)
#68
#69
#70
Happened to see this forum while searching with google, this thread is of interest to me because Sept. this year my 2009 standard coupe with 26000 or so miles started giving off a strong gas smell in the garage, took it to a dealer and it was determined the fuel module had a small crack in it, I paid nearly 3 thousand to get it replaced. They found it using the smoke test.
I contacted GM with the information and all they said is it is no longer under warranty.
I did the form today. By the way the replacement part was defective, the sending unit was bad and gave a false reading which was replaced one week later.
#71
#73
So I've been living with this fuel odor since I bought my C6 from a friend a few months ago. It's really stout and permeates my house though the garage door. So after doing some research on this looking for common issues I came across this thread. I pulled my driver side fender liner last night and sure enough it's leaking from the top of the tank and running down the side. Now, it's more of a seepage down the side since it's not making a puddle and it looks as if it's been doing it for a while. There is a foam pad between the tank and the metal louvered support plate that holds up the tank. I can't see any leaks coming from underneath because the foam is soaking up fuel like a sponge. So all of you that are at a loss for definitively locating your fuel smell, I highly recommend pulling that left rear fender liner.
RainMan12 mine is leaking to the left of the tank (as pictured above) where the indention in the tank is, not where yours was leaking next to that "U" shaped fuel line. Had I not taken off the fender liner I would not have seen it. I've been all under this car and all looked nice and dry. No MILs so I know it's not a cracked tank or else I'd be pulling EVAP codes. I'll be knocking this project out over the weekend and hopefully have a couple pics to post. I may also make a youtube video to illustrate for other C6 owners where their leak may be coming from. It won't be a step by step just for diagnostic reference.
I'll fill out the form after I get the job done so I can properly describe to the NHTSA what the fix was.
#75
#77
The photos I posted were taken with the rear wheel and wheel-house liner (fender liner) removed. The dynamics of where the leak occur may be different in your car. If the fuel pump fitting is leaking, it actually creates a small high pressure SPRAY of fuel, and the direction of the spray may change depending on the direction the crack is pointing in. This spray only occurs when the engine is on and the fuel line is pressurized.
I have heard a couple reports of cracks in the tank itself, so there may be more than one failure scenario. Hopefully NHTSA will take action on this if we can get enough folks to report the issue.
#78
Hopefully you don't have an automatic car. If so, you'll need to put the car on a lift and remove the transmission, rear end, and main rear suspension member before you can even think about pulling the tank. It's a big job any way you slice it.
I guess it is my turn ,Car goes to Dlr on tuesday .
I have been quoted 2k for the fuel pump replacement.
I looked up an Aeromotive pump for the car but they say they realy are not plug and play so the drama goes on .I guess I will have to go with the extended warranty and see what they say,lucky I have one of those my car just clicked 50k last week when it was at the Chevy Dlr last week for the rear end noise
Ah just threw a solid code I disconected the battery and cleared the codes .16 miles later threw a check engine light again I checked the codes and it is a po code and engine has what feels like a slight miss at idle.
I will try and get some pics
#79
For those that can't smell ,When I get out of my car I can smell the fuel as I get out of the seat when exiting the car , my nose is right at the gas tank door.If you open the gass tank door you can see a lot of dirt inside the gas cap and inside the door.
