Passenger side window
Nov 17, 2014 | 03:26 PM
When I close my passenger door, the window does not automatically roll up to create a tight fit against the window weather stripping. Does anyone know any ways to troubleshoot this, or do I need to replace the motor or a sensor?
Any advice would be grea! Thanks.
Nov 17, 2014 | 03:40 PM
have you tried to re-index it?
Nov 17, 2014 | 03:46 PM
Quote:
Originally Posted by
tennblkc6
Quote:
With the engine running and the window down, close the car door. Raise the window and hold the up switch an extra 3 seconds. Release. Without lowering the window, hold the up switch again for 3 seconds. Release. Done.
This needs to be done to both windows every time the car battery is disconnected, then reconnected.
Jan 6, 2015 | 07:57 AM
2008 auto. sometimen when press brake dash go on/ off at starting any sugestions
Reason: maeby others has the same problem
Jan 6, 2015 | 08:05 AM
From: Currently somewhere in IL,IN,KY,TN,MO,AR,MS,AL, or FL
Did you solve your window issue or are you just
Jan 6, 2015 | 08:09 AM
vette_dd
thanks a lot , problem solve
Jan 6, 2015 | 08:12 AM
vette_dd
thank you problem solve
Jan 6, 2015 | 08:13 AM
fortmorganal
did you solve your window issue or are you just
yes my friend problem solve
Jan 6, 2015 | 08:15 AM
fortmorganal
yes my friend problem solve, no more water inside when washing , thanks a lot .
Jan 6, 2015 | 08:18 AM
fortmorganal
yes problem solve, thank you
May 21, 2018 | 06:02 AM
roll up window
FortMorganAl
yes thanks for ask , my other concern is my 2009 Z06 is very noisy inside cockpit when traveling in open x pres way, any suggestion ?
May 21, 2018 | 08:42 AM
Z06's are noisy by nature. Sound deadning material and newer tires help a little.
Clif
