Driver Window Switch Bezel Removal
Old Dec 6, 2014 | 11:47 AM
vet55's Avatar
vet55
Default Driver Window Switch Bezel Removal
s
I want to remove the above switch. I get it about 40% out and it stops and scared as hell to force it. Any suggestions? Thanks ahead.
Edit:
The answer was to pull harder and it will come out. The even harder part was getting the switch out of the bezel. After a long fight of persistent prying it came out and did break the original housing. Oh well.
The good news is it all goes back together easily and looks great so it is worth the headache.
Thanks for reading.
Old Dec 6, 2014 | 01:48 PM
vetteright's Avatar
vetteright
When I changed mine out I took the door handle off and punched it out from underneath. No damage that way. But I had to take the door panel off, anyway as I was changing the door lock bezel also.
Old Dec 6, 2014 | 01:50 PM
vet55's Avatar
vet55
Thanks. I am not ready for the door panels yet.
Old Dec 6, 2014 | 02:22 PM
BWF07's Avatar
BWF07
St. Jude Donor '11
Oldtimer
It was a little difficult to get the bezel to pop out, but as far as the switches, they were no problem. I took my time and a small straight slot screw driver to get the little latches to release.
Old Feb 25, 2018 | 09:06 PM
Jon05vette's Avatar
Jon05vette
2016 C6 of the Year Finalist
Default Door switch bezel
Can you explain how u popped the window switch bezel out. I tried carefully prying it out from the front side and heard a spring like sound. It seems to be stuck on the door panel side and m afraid to pull any harder at this point.
Thx. Jon
Old Feb 25, 2018 | 10:12 PM
Knob Jockey's Avatar
Knob Jockey
St. Jude Donor '11-'12-'13-'14-'15
Just keep prying on it, it'll pop out.
Old Feb 26, 2018 | 01:40 PM
Jon05vette's Avatar
Jon05vette
thanks!
Old Aug 11, 2018 | 05:55 PM
andersd's Avatar
andersd
3rd Gear
Default drivers window switch replacement
I have 2007 Corvette and the drivers side window switch will lower the passenger window but will not raise it. I thinks its the switch so I am trying to remove it from the drivers side but cannot get it out, is there a video to show how to do this> I try prying on it but cannot get it to come out
Dave
Old Jan 10, 2019 | 04:08 PM
Gscafidi's Avatar
Gscafidi
Dave
Hi Dave. Just saw your post. I have the same issue with the driver side switch not raising the passenger window back up. I was able to replace the driver side switch with a new one but still have the same issue. I was wondering what happened with your situation. Thanks george
Old Jul 18, 2019 | 02:51 PM
CamarosRus's Avatar
CamarosRus
On My 2012 GrandSport the Drivers Door Switches for Both Windows and Both Mirrors no longer operate the same.....
Lock Icon On Dash
We have tried most every procedure known to this forum and owners manual to NO avail...............
Chuck S Auburn,WA
Old Aug 4, 2024 | 08:59 PM
metri4's Avatar
metri4
Navigator
Default Issue resolved?
Lock Icon On Dash
Chuck S Auburn,WA
Did you ever get that fixed? Currently having the same exact issue
Old Aug 4, 2024 | 09:35 PM
4SUMERZ's Avatar
4SUMERZ
Typically, its a connector pin issue either due to fretting, or needs cleaning at the pins. These connectors are found in the driver door 10 pin connector and or in the passenger door 5 pin connector. The grounds connection should also be checked if the connectors are not the issue.
Old Aug 5, 2024 | 10:39 AM
metri4's Avatar
metri4
Navigator
Default Cleaning method?
Thanks that is very helpful. I have taken the entire switch apart and cleaned the circuit board. What method would you suggest for cleaning the pins? I was thinking to put some dielectric grease in after cleaning as well.
To Driver Window Switch Bezel Removal
