05 column lock?
Dealer solution, replace it with a new new lock that will do the same in time as well.
Better solution, install the eliminator instead.
Short version, the steering column lock has a unlock and lock resistor on it to tell the RCDLR when its either locked or unlocked.
With the eliminator, you put the steering lock into the unlocked position, unplug it, then install the elimnator relay in the plug instead.
So instead of the lock actual working, the eliminator has a relay that is fired one way or the other via the voltage off the plug, then on the other sensors wires, resistors that give the needed resistance voltage for the RCDLR to think that the steering column lock is in the correct position.
Hence you no longer need to worry about the gears binding up, and since it just a relay that is being fired, even a low drained battery had more than enough power to fire the relay into the correct position to give the RCDLR the needed resistance as well.
As for which, would go with the one from Ebay since that is the original designer of the device (used to work for COH and built them for them, left and COH is now having someone else build them for them instead.
