2009 Nav Screen Problem
Old Dec 15, 2014 | 07:14 PM
my1stvette98's Avatar
my1stvette98
Default 2009 Nav Screen Problem
After not driving my 2009 3LT coupe for several weeks the screen on the system will not work but the radio is on. After a while it comes on and once driven it comes on every time. This car is still under certified warranty 12/31. Just trying to figure out if I need to have it repaired if this is abnormal. Thanks.
Old Dec 15, 2014 | 07:59 PM
EVRose's Avatar
EVRose
A weak battery can cause funky stuff to happen to the sat nav operation. Have your battery tested.
Old Dec 15, 2014 | 08:03 PM
RicK T's Avatar
RicK T
Some cars, mostly '09's it seems, had a software timing anomaly that caused that. There was a TSB to update the software.
The TSB is in post 3 in here:
https://www.corvetteforum.com/forums...lay-blank.html
Old Dec 16, 2014 | 07:52 AM
Uncle Meat's Avatar
Uncle Meat
I had this exact issue and had my local service department order the firmware update DVD. Once it arrived (took 2 weeks) they were able to update the firmware in about 10 minutes. However.... after having this done it seemed to clear up the issue for a couple months, but it has started doing it again. No video output, however everything else works (radio, cd).
U.M.
To 2009 Nav Screen Problem
