Mirror drops down
Old Dec 15, 2014 | 10:55 PM
ROD BROWN's Avatar
ROD BROWN
Default Mirror drops down
The title says it all. Is there a screw or bolt that will tighten the mirror so it doesn't drop down. I have to tip up the mirror every so often.Any suggestions greatly appreciated. Rod
Old Dec 15, 2014 | 11:12 PM
owc6's Avatar
owc6
Which mirror?
Old Dec 15, 2014 | 11:14 PM
budgreen3564's Avatar
budgreen3564
There's three small rods inside that hold the mirror in place. These oem rods bend over time. They need to be replaced with harder stainless steel rods. Do a search. Forum member used to mail these out.
ROD BROWN's Avatar
ROD BROWN
Default Oops!
Originally Posted by owc6
Which mirror?
The rear view mirror inside the auto.
Old Dec 16, 2014 | 02:51 AM
Dano523's Avatar
Dano523
Ditto,
to make the pins get .078 (2mm) piano wire from a hobby shop and cut it into 3 1 inch pieces. .078 piano wire usually comes in 3 foot lengths for a dollar or two
To add, if you need it even stiffer, such as in the case of mounting a radar detector under it, you can use stiffer pins, hence the back ends of 5/64 drill bits (use a Dremil to cut the back section off). Also, you can use A-2 round stock rod, but will need to heat treat the pins to harden the steel.
Old Dec 16, 2014 | 10:02 AM
4SUMERZ's Avatar
4SUMERZ
Here are instructions to remove mirror and fix pins
Old Dec 16, 2014 | 11:05 AM
ROD BROWN's Avatar
ROD BROWN
Default Thanks for the info
Thank you for the info. Will go to the shop to buy a length of stainless steel rod.
To Mirror drops down
