Power steering fluid is low on a my 2007 corvette the book calls for GM pn 89021184 or equivalent so whats equivalent and what brand does everyone use I have a bottle of AutoZone power steering fluid form my other car will that work ? Thanks
You'd probably be ok with almost anything.
But why take the chance?
If you use something that causes damage, you'll be looking at hundreds of dollars and a lot of frustration to get it fixed.
BTW, if you need to top off more than a couple of spoonfulls about once every 20k miles, something is probably leaking and that will need to be fixed at some point.
