c6 window
Old Dec 31, 2014 | 10:48 AM
michaelangelo's Avatar
michaelangelo
5th Gear
Default c6 window
What was the procedure for fixing the window . It doesn't go down before door closes. Now can't close the door??
Thanks...anybody
joey
Old Dec 31, 2014 | 10:53 AM
RocketDawg's Avatar
RocketDawg
CI 6-7-8 Veteran
St. Jude Donor '09
Strictly from memory, but I think you sit in the car with the door closed, put it in Accessory mode, lower the window and hold the switch down for a couple seconds, then raise the window and hold it for a couple seconds. If you can't get the door closed, try it with the door open.
You can search for "Indexing windows" if that method doesn't work.
Old Dec 31, 2014 | 11:13 AM
1bdvet's Avatar
1bdvet
U.S. Air Force
St. Jude Donor '05 thru '26
Indexing the windows, bring both windows up, then release the buttons and immediately push both buttons up, and release and there indexed.
Old Dec 31, 2014 | 11:14 AM
Vette_DD's Avatar
Vette_DD
From the owner's manual.
With the engine running and the window down, close the car door. Raise the window and hold the up switch an extra 3 seconds. Release. Without lowering the window, hold the up switch again for 3 seconds. Release. Done. Don't forget the other window.
Old Jan 2, 2015 | 07:41 PM
Vet Interested's Avatar
Vet Interested
What's an owners manual?
Old Jan 2, 2015 | 09:16 PM
Vette_DD's Avatar
Vette_DD
Something that's slower than us.
To c6 window
