Battery Question
Old Jan 5, 2015 | 08:23 PM
dbirdhouse1's Avatar
dbirdhouse1
Default Battery Question
I'm thinking not big but this is the place to ask; as I was installing an Optima Yellow Top I noticed there was nothing covering the negative terminal and yes, the red piece was covering the positive. Need I be at all concerned?
Old Jan 5, 2015 | 08:29 PM
Aiblinger's Avatar
Aiblinger
No need for concern... Just always be sure not to confuse the terminals. It is normal to have a cover over the positive and I've never had a car with a cover over the negative terminal.
Old Jan 5, 2015 | 08:43 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
Actually, our 2006 had a cover over the negative terminal but our 2009 does not.
Since the negative is connected to ground on the car frame, "shorting" from the negative terminal to the frame shouldn't do anything.
Shorting across both terminals, or positive to ground, is a whole 'nuther (bad) story.
Old Feb 28, 2015 | 07:49 PM
drdots's Avatar
drdots
4th Gear
Default Terminal Covers
Del City sells what they call straight terminal insulators. Come in 3 sizes and both red and black. Not sure which size is correct but all 3 are less than the cost of shipping.
Old Feb 28, 2015 | 07:54 PM
VET4LES's Avatar
VET4LES
No problem.
Old Mar 1, 2015 | 10:07 AM
LUVMINE's Avatar
LUVMINE
St. Jude Donor '13-'14-'15-'16-'17-'18-'19-'20-'21-'22
Gm stopped putting on the black negative cover. Not sure exactly what year. My 2007 had it, my 2012 does not.
Old Mar 1, 2015 | 01:57 PM
drdots's Avatar
drdots
4th Gear
My 2013 has it.
Old Mar 1, 2015 | 02:09 PM
LUVMINE's Avatar
LUVMINE
My 2012. I must have got robbed.
To Battery Question
