Seat Removal
Old Jan 6, 2015 | 02:54 PM
LbulletM's Avatar
LbulletM
Default Seat Removal
I know that because of the air bag connections, it's not safe to disconnect them while the battery is attached...
What I'm wondering, is it ok to reattach the battery and drive around without a seat connected, or will I be at risk of an airbag deployment?
(I'm going to be reupholstering).
Old Jan 6, 2015 | 03:13 PM
wayback's Avatar
wayback
As long as the airbag connector is unplugged you should be fine. That plug only connects the airbag in the seat.
Old Jan 6, 2015 | 03:15 PM
LbulletM's Avatar
LbulletM
I don't think I even have seat airbags. I have a 1LT. So there's no chance of the dash bag deploying?
Old Jan 6, 2015 | 03:29 PM
wayback's Avatar
wayback
No. The crash sensors are mounted in eng bay, below hood and on side frame rail.
Old Jan 6, 2015 | 03:33 PM
LbulletM's Avatar
LbulletM
Awesome! Thanks!
Old Jan 6, 2015 | 04:56 PM
4SUMERZ's Avatar
4SUMERZ
I have the sport seats with air bag, and I removed the seats without disconnecting the battery. Once the air bag plug is disconnected under the seat, it's safe.
Old Jan 6, 2015 | 08:26 PM
dennis50nj's Avatar
dennis50nj
yet gm could tell how many times i took them out with a tech 2
Old Jan 6, 2015 | 08:39 PM
LbulletM's Avatar
LbulletM
Thanks all. Was weary of starting in case I couldn't get it back in same day. Now I can just work on it over a couple of nights after work.
Old Jan 6, 2015 | 08:44 PM
dennis50nj's Avatar
dennis50nj
it can be removed in less then 5 minutes, put a towel on the rockers, to protect from scratching also adjust the seat base same front and back and fold seat forward
Old Jan 7, 2015 | 01:34 AM
HOXXOH's Avatar
HOXXOH
I've had my driver's seat in and out about 6 times in the last week. First to install the rollbar, then a few times to fab a new race seat mount, then to go racing and swap seats there and again before coming home.
I think I'll get a friend to video how to remove a seat and put a utube link on the forum. If a Tech II records how many times seats are removed, the results better have 3 digit capabilities.
BTW, I never disconnect the battery.
Old Jan 7, 2015 | 08:46 AM
LbulletM's Avatar
LbulletM
Haha thanks guys, but I meant I'd work on the recovering over a couple of nights, not the seat removal.
Old Jan 7, 2015 | 12:03 PM
HOXXOH's Avatar
HOXXOH
I drove over 1700 miles between last Friday and Monday without a passenger seat and without the airbag connected on the driver's seat. About 100 miles of that was with a race seat that had no electrical connections at all.
You won't have any problems removing or driving with unconnected seat wiring.
Old Jan 7, 2015 | 08:18 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
In addition to the other tips, removing the seat is easier if you remove the roof (coupe) or fold the top (vert).
Old Jun 9, 2016 | 02:08 PM
tbevins's Avatar
tbevins
I just bought this 05 and the seat stopped moving forward\backwards, its stuck all the way back, which is fine for driving, but I cant move it forward to get to the back bolts to remove it. I pulled the front nuts and about $30.00 in coins from under the seat. I'm sure theres a coin or a habdfull fo them, in the tracks, I can hear the seat try to move when I hit the button, I'm thinking the motors going to get burned up trying to esy entry back n forth with the trcks bocked.
If anyone has an idea for removing the seat, moving it forward somehow, etc, I would love to hear it.
Old Jun 9, 2016 | 10:42 PM
SilverC54me's Avatar
SilverC54me
Had this issue on a C5. Had to use an open end wrench to get to the bolts. It was a slow process. On the C5 the issue was a bad seat control switch panel.
If as you indicated found a ton of coin under the seat there are probably some caught in the track. It is just going to be a slow process to get the two back nut undone.
Gary
Old Jun 9, 2016 | 11:09 PM
tbevins's Avatar
tbevins
Thanks Gary, I'm gonna try to blow it out with air compressor, I don't have a lot of faith in that tho. I can maybe teach the driver's side nut, but I can't even see the passenger's side nut in the driver's seat, rear. ...sucks, never carrying change around...ever..
Old Jun 27, 2016 | 06:45 PM
tbevins's Avatar
tbevins
Can anyone confirm this connector with the purple clip is the problem child ? I had the dealer run a diagnostic and it showed a bad ground in the seat connector, that was causing the airbag light.
To Seat Removal
Old Jun 27, 2016 | 07:45 PM
Dcasole's Avatar
Dcasole
That is the seat connection , but u state you have an air bad light on ?
The ground is the thick black wire in this bundle
Dave
Old Jun 27, 2016 | 07:49 PM
tbevins's Avatar
tbevins
Thanks! Yeah the airbag light is on, diagnostic says is caused by a bad ground in the seat connector. I wanted to pull the seat but I can't bc there's change jammed in the rails and it's moved back over the rear bolts. So I turned off rest entry for now and I'm trying to fix the airbag light. Hopefully done dielectric in that connector and a ziptye will shut that light off..
Old Jun 27, 2016 | 08:27 PM
tbevins's Avatar
tbevins
Fnk light is still on.
