OnStar/Bluetooth
Jan 11, 2015 | 02:17 PM
OnStar/Bluetooth
When you disconnect (pull) the fuse for Onstar, does it have
any affect on Bluetooth and the steering wheel controls?? Or are they completely unrelated?
Thanks!
Jan 11, 2015 | 02:35 PM
2015 C6 of the Year Finalist
Jan 11, 2015 | 02:38 PM
Quote:
Originally Posted by
Hameister
I take it you do not know?
Jan 11, 2015 | 02:43 PM
Vet Interested
Correct, if I knew, I'd help. I decided to check in and perhaps learn something.
Good luck!
Jan 11, 2015 | 02:44 PM
Hameister
Good luck!
Thanks. I may need it!
Jan 11, 2015 | 03:02 PM
Jan 11, 2015 | 03:28 PM
How do I connect iPhone to Bluetooth on my GS. I have onstar n Nav. Can't find where on screen say to connect.
Jan 11, 2015 | 03:32 PM
whit1
Can you spell HIJACK?
Still hoping for an answer.....
Jan 11, 2015 | 04:40 PM
Here is the Onstar Bluetooth thread that should answer your questions. I believe the Bluetooth connection is done through the steering wheel and the DIC.
https://www.corvetteforum.com/forums...tar-nanny.html
Jan 11, 2015 | 04:44 PM
Enterprisehunter
Thanks, I'll check it out.
(I did look it over but being as dense as I am I do not see the answer).
Reason: Did not see the answer in the suggested post...
Jan 11, 2015 | 07:11 PM
Our 07 Z didn't have On Star, and Bluetooth worked fine for phone pairing and steering wheel controls.
Our GS has both. (On Star and Nav) My feeling is your phone should work fine with your nav even with the On Star fuse pulled.
I would give it a try..
Unrelated would be the simple answer.
Jan 11, 2015 | 07:16 PM
2k Cobra
That helps. Thanks 2k Cobra
