New C6 article...
windows, and the new dual camshaft, displacement-on-demand
GenIV small-block.
Here's a 1999 SAE paper abstract from GM on hydroformed aluminum:
1999-01-3180
Publication Date: 09-01-1999 Information Group: Technical Papers
Language: English
Abstract: In a typical hydroforming operation, a round tube of constant wall thickness is bent
into the overall shape desired for the final part, then placed between a pair of dies. Despite
some small percentage of stretch that may occur as the tube expands, the wall thickness in the
original tube is therefore substantially constant at all points. In some circumstances, a part
is locally thickened or reinforced for extra strength. Normally, this is achieved by using a
separate piece of reinforcement at selected location. In this paper, it is intended to present
a unique method to achieve an optimal structural design allowing thin or thick gages where
required along its cross-section. This is done via hydroforming an aluminum extrusion tube to
an optimal frame structure having varied wall thickness to satisfy various loading requirements
at a minimum weight. The engine cradle is used as an example to demonstrate this methodology.
The finite element model in conjunction with an optimization software has been used to determine
the variable gage thickness for various locations of the structure under all the required loading
conditions. The advantages of using varied wall thickness design over the constant wall design
was proven out in this example. Approximately 37% of mass reduction is achieved with this unique design.
Author(s):
Name Affiliation
Chi-Mou Ni General Motors Corp.
Charles J. Bruggemann General Motors Corp.
Tasnim Hassan General Motors Corp.
Wallace Hall General Motors Corp.
Other Info: Publisher: Society of Automotive Engineers, Inc., Warrendale, Pennsylvania, USA
Publishers Segment: SAE
Country of Publication: United States
Document Source:
Document Category: N/A
Meeting Name: International Body Engineering Conference and Exposition
Meeting Location: Detroit, Michigan, USA
Meeting Start Date: 09-28-1999
Meeting End Date: 09-30-1999
Polycarbonate windows: The company appears to be EXATEC.
http://www.exatec.de/do/en/frame.asp http://www.bayer.co.uk/news/windows_0602.html http://www.engineeringtalk.com/news/fro/fro153.html
GenIV small-block. I'm certainly not privy to GM plans but
I find it implausible that the new GenIV small-block is
going into some 2004 trucks but the new C6 is going to use
a GenIII engine
If memory serves me correctly, Electronically actuated valves were used in Formula 1 cars back in the late 80's early 90's. Thus making it old tech.
The problem they had to deal with was engine size and weight. Granted much time has past and I'm sure it is possible to make the system lighter and smaller.
But that's why I noted it as old tech.
Justin C.
If instead you use solenoids to push the valves open then you can have a computer control the opening of the valve and this gives you nearly infinite control over the timing. This can give you major increases in efficiency and horsepower since you are able to cater the timing to any rpm value.
[Modified by TripleBlack99, 2:00 AM 8/8/2002]
EAV tech would probably allow the manufacturers to get rid of this component also.
Now the question is, will this new "camless" engine also be direct injection direct fire engine also? :blueangel:
[Modified by H82BFST, 5:23 AM 8/8/2002]
Name an example - a poppet vavle four stroke, not a two-stroke or a sleeve valve (driven by cranks and rods) Bristol.
Duke
Duke
