Traction contol button
Old Jan 18, 2015 | 10:14 PM
harold50's Avatar
harold50
Default Traction contol button
2005 z51 c6 vert. I get no response at all from pushing it......i have read the threads and understand how it works.
Is this button lighted ?
If so i will track down power issues to the switch.
Car is new to me.
Old Jan 18, 2015 | 10:26 PM
05_Z51's Avatar
05_Z51
Car is new to me.
I don't think its lighted. Car is parked for winter but i remember noticing the same thing.
Old Jan 18, 2015 | 10:49 PM
Vette_DD's Avatar
Vette_DD
Not lighted, but you should get some kind of message on the DIC whenever you press the button.
To turn the system off,
press the button located
on the console. You
can turn the system on or
off at any time by
pressing the ACTIVE
HANDLING button. The
DIC will display the
appropriate message when
you push the button.
(Page 4-10 of the 2005 Owner's Manual)
Old Jan 18, 2015 | 10:53 PM
harold50's Avatar
harold50
NO message at all
Old Jan 18, 2015 | 11:41 PM
ttx350z's Avatar
ttx350z
As stated, you should get a message on the DIC and the illustrated amber light of the car with squigly lines on the speedo side.
Seems as if your's isn't responding for whatever reason.
Old Jan 19, 2015 | 12:29 AM
05_Z51's Avatar
05_Z51
NO message at all
Blurry pic but that's the "traction control off" light above the needle there. Light is on when traction control is off.
And even then, you have to hold the button in for 4 seconds to switch modes. And you will hear a beep once it switched modes.
Old Jan 19, 2015 | 12:33 AM
mpuzach's Avatar
mpuzach
I no longer have my '05 but I'm 99% certain that the button was lighted.
Old Jan 19, 2015 | 11:11 AM
Vette_DD's Avatar
Vette_DD
It's possible, but for sure, it doesn't light up on my 012, I just tried it with the engine running. Just puts a message on the DIC when I press it.
Old Jan 19, 2015 | 11:20 AM
EVRose's Avatar
EVRose
First thing I'd do is pull the center console and make sure the button is connected to the wire harness. HERE is how you do it.
Old Jan 19, 2015 | 11:45 AM
CyberBullet's Avatar
CyberBullet
Whoa! 250KM an hour! I bet your fuel tank was full when you started that run... You are going to need to fill up soon at that rate.
Old Jan 19, 2015 | 12:28 PM
orca1946's Avatar
orca1946
That fast and you are taking a picture?????
You are going to need more than traction control!!
Old Jan 19, 2015 | 12:38 PM
LMB-Z's Avatar
LMB-Z
I had an 05 and I'm pretty sure it was not lit. As stated earlier, remove the console and make sure it is connected.
Old Jan 19, 2015 | 01:33 PM
mhatton222's Avatar
mhatton222
Nice pic that could support its own thread!! 150 at night one-handed? Maybe someone else snapping pic? You have extra large Juevos Sir!
To Traction contol button
