Flat Tire Repair
Flat Tire Repair
I've seen all kinds of posts debating the virtues of a flat tire plug kit and compressor versus a seal/inflator kit. I have a 2012 Grand Sport vert and am about to replace the original tires. Deciding between run flat and non-run flat and I know the pros/cons. Question I have...has anyone actually had to use a seal/inflator kit? If so, did it do the job? Any problems? What brand do you have? Thanks!
As a guy who changes Motorcycle tires for a hobby... Almost 100 tires last year.
I would suggest that you stay away from fix-a-flat or any canned sealers.
It is a complete mess to clean off of the inner wheel, not that it would be your problem because you would be going to a shop and some poor fool in the back would have to clean up the mess...
And it will destroy the TPMS in that wheel.
Compressed CO2 or a battery operated compressor and a plug kit is what you should consider.
I love my Michelin ZP's so I wouldn't change my tires to non run flats.
I had a flat on Interstate 10, 100 miles east of Tucson, 200 miles from N.M. and NO shop in between. Sealant/inflater got me back to Tucson. I will never travel without such a unit ever again. I bought a fancy German pump/sealant kit, but GM makes one for each Caddy SRX. Plugs sound good but are almost impossible tom use on the side of the road.....
Race Car Tech
I used a plug kit on a road trip, 1200 miles from home. The TMPS gave me the warning, and I kept an eye on the tire pressure until the next rest stop. It was a slow leak, cause by a screw imbedded in the rear tire. I used the compressor to pump it up approx. 5 psi over pressure. When we stopped at the hotel later in the day, the pressure was down to normal pressure.
I found the screw, used my side cutter pliers to pull out the screw, and plugged it on the spot in the hotel parking lot.
That plug stayed in that tire until I got a new set a year later.
I carry a can of slime, but would only use it in an emergency.
It's important to carry side cutter pliers to pull out any nail or screw that you might pick up. Without those, your never going to be able to plug the tire properly.
NSF
I've successfully 'plugged' the rear tire on superbikes four times with the Genuine Innovations repair kit. One had two nails an inch apart. Every tire held air and lasted until the tread wore out. I have FS WO RFs and would still attempt to repair a flat if I got one using the same kit. As mentioned, over inflating is helpful when plugging a tire.
If a tire is holding air with a screw in it, I would leave that screw alone until I got home. Stop evry hundred miles or so and add air but pulling the screw is, to me, asking for trouble. And of course every tire manufacturer says that plugging a tire from the outside is not the correct way to repair a puncture long term.
Here's a great compressor to carry. Inflates up to a 31 inch tire in no time. I picked up a nail in my Pilot super Sports non-run flat and pressure went to 24 pounds. Inflated to 33 pounds in a matter of a couple minutes. I also carry a slime plug kit. i did not plug the tire as the nail sealed the tire but had it patched from the inside the next day. Here's the compressor:
Received 2,051 Likes
St. Jude Donor '13
Big wide tires, a lot of area to search for the nail. Longer reach under the car if it's toward the inner part of the tread.
It can be done, and people have done it. But it ain't like throwing a quick plug into a motorcycle tire.
St. Jude Donor '13
If you have non-runflats, a flat may unseat the bead and the sealant won't work, I've seen pics of C5 Z06's on a flatbed for that reason.
Received 1,675 Likes
I tried to plug a tire on my driveway once and couldn't get it to work. I could imagine what it would be like by the side of the road at night trying to do it.
My take from all the threads I've read, is that sealant/infiltrators, as well as plug kits of various types, work well about 50% of the time.
The other 50% is spent wishing they'd bought Run Flats.
I picked up a screw about a year ago. The DIC showed me 18 lbs. in the R/Front.
I drove to the nearest repair facility for a proper inside vulcanized patch, and was glad I had the Run Flats.
What ever you choose, good luck.
Yea....you definitely don't want to do the plug thing if you haven't done it before and are pretty comfy doing it. One of the biggest hassles is finding the leak if the culprit nail...etc....isn't still in the tire.
Race Car Tech
The rear tires are a bit more troublesome, but can be done as well.
On our road trips, we only drive from 7Am until 3-4PM daily, so there is no worry of doing anything during darkness.
Most times as already mentioned, a nail in a tire will most often only produce a very small leak, that is manageable by pumping up to pressure occasionally until you can get it fixed at a tire service shop.
