I was changing oil and adjusting rear toe in on the rears on a 2011 GS.
To my surprise I found two greasing fittings on the toe-in arms.
Are there any more than two grease fitting that need to be serviced?
thx
gn
I may be wrong, but I think only 2, I have a 05 and that's all there are on mine. Don't put a lot of grease in them, if you use too much it could end up on the wheels and rotors. I know because I did it.
All C6's, all years and all models that had the Z51 or Z16 option including Z06, GS, ZR1. Only the base suspension cars did not have them.
Not sure about F55/MSRC equipped cars
Thanks for the answer. I have bought the shop manuals. I was going to head out to the garage and research this in the shop manuals. Saved me actually having to read. Ha Ha Ha
I didn't know about these and guess I need to check too. Can you get to them without lifting the car? Anyone have a pic of their location? Thanks
I'm able to reach the fittings on our GS by reaching through the spokes in the wheels. If your arms are long enough, you can reach around the tires and grease them that way. You can run the back wheels up on a ramp and crawl under the rear of the car and reach them that way.
Thanks for the info. I will take a look this weekend and should be able to get to that with no problem. I appreciate the response.
