New seat cushion replaced what a diffference!!
I bought a heavy duty foam replacement seat cushion from DJ Motorsports and put it in today. It's not the easiest project, but certainly worthwhile. The old stock one was nearly cut in two by the seat springs, and the seat frame on the left side.
Mark
Mark
I did the upgrade kit as a precaution. My car only had 6000 miles on it and the foam already had cuts in it from the sides, as well as the bottom wires. The kit I got had a jute pad that covered the wires.
Mark
I just installed the same seat because I was changing out the upholstery. According to the website, the foam is supposed to be a better quality. I did the repair kit on the passenger side since it is not used as often.
Chevy Again, thanks for the reply. I'll be sure to allow lots of time when I do mine.
Airmed2, thanks for the heads up. I've got about 7500 on mine so I guess I can pretty much expect than mine have cuts too.
I have 18k on mine and there was only one small cut just starting. No doubt overtime the foam would have ended up destroyed.
